How is this possible...
I've had two inter cooler o rings blow out recently... I don't even know how it's possible for 1/2 the o ring to end up outside the piping assembly. The inter cooler is bolted firmly in place, so no movement there. Only running 1 bar boost. Anyone else experience this?
87 930 GHL/Rarlyl8/Garretson/GT3582R/1 Bar/Wevo shift, mounts/Meth inj/LM-2/Custom Fuchs/Carrera intake manifold/Xtreme Carrera heads P&P/3.4/DR 993SS cams/ Mahl/Pauter/JE/Niresist/ARP/twin COP/8.25:1/KEP stage 2/twin tials/close 2,3,4th. MS3Pro Evo 500+ HP, BTSOMP Dyno
Old 08-08-2018, 04:36 PM
speednme1's Avatar
did you try adding one of these too https://www.pelicanparts.com/cgi-bin/ksearch/PEL_search_2016.cgi?command=DWsearch&description=intercooler+seal
Rey....77 930 "the Mistress"
Old 08-08-2018, 04:46 PM
Originally Posted by speednme1 View Post
cool product... but more than 10 yrs of ownership and many smiles, and this hasn't been a problem before.
Old 08-08-2018, 05:16 PM
Hi Phillip
I put a silicone hose over the connection point, with 2 hose clamps. I'll send you pic.
1988 Porsche 930 Targa - 3.4L Twin Plug Motor, DC 13 Cams, Supertec Head Studs, ARP Rod Bolts, Port and Polished Heads, Garretson Andial Intercooler, GSX 61 BB Stage 5Turbo, Tial F46 WG .8 Bar Spring, PowerHaus Headers, Rarly8 Dual Tip Muffler, MS3 Pro EFI conversion, 85lbs. Injectors, Center Force Stage 2 Clutch , Rebuilt 4 Speed with LSD.
Old 08-08-2018, 05:24 PM
908/930's Avatar
Hey Phillip,
Is that O ring hollow? looks that way in the pic.
Is there a chance that there is a lot of clearance in the tube that the intercooler fits into?
Otherwise my bet is the intercooler is lifting out of the tube, at 1 bar there is a lot of pushing force there. About 100lbs push at 1 bar. How quick is your blow off valve?
Old 08-08-2018, 06:41 PM
mark houghton's Avatar
It happens to everyone at some point. My theory is that the o'ring material over time gets softened by the heat and possibly oil mist (all turbos spit a little oil past the seals, dependent upon their age). Once soft enough, they can deform out of position when on boost. Put their replacement on your scheduled PM list.
Mark H. 1987 930, GP White, Wevo shifter, Borla exhaust, B&B intercooler, stock 3LDZ.
Old 08-08-2018, 07:04 PM
I like the idea of adding a silicone coupler but, with T-clamps as opposed to standard hose clamps.
81 Pacific Blue 930 Euro coupe slicktop on a strict diet, Rarlyl8 headers, Blowzilla turbo, Tial waste gate, Full bay I/C, Home made center out exhaust, Leask WUR, MSD 6AL, PLX wideband
Wevo shifter, LSD. Next up, Cams, Heads and port work
Old 08-08-2018, 07:40 PM
Chain fence eating turbo
No burrs in the land?
Old 08-08-2018, 08:06 PM
Originally Posted by 908/930 View Post
Hey Phillip,
Hey Rod, no, O ring is not hollow... it's one from Pelican, it's only a couple of weeks old at the most. I can hardly push the boost pipe on to the inter cooler it's so tight, even with a bit of lube. no play what so ever. There is a small bit of miss alignment once its hooked up though, as you can see in the pic. No way the inter cooler can lift, as you can see all the supports/bolt down connections...
Old 08-08-2018, 08:09 PM
nope...
Old 08-08-2018, 08:12 PM
O rings are designed to take around 1500 PSI before needing reinforcement, so beings you’re 1/100th of that, it’s tearing from movement.
Old 08-08-2018, 09:36 PM
maybe that o ring was made on a Monday.
A little silicone divers grease works good on them.
Old 08-08-2018, 09:45 PM
908/930's Avatar
Hmmm, how is the other end of that up tube connected to your GT35? Silicone hose? Is there any chance of movement there or the turbo mount flexing?
Old 08-08-2018, 11:25 PM
Have had the same problem and I suspect the hose between the turbo and the up tube is bulging under boost shortening the assembly. The o-ring is then free to escape...
Many projects on the way...
1987 930 Road trip car (1/2 owned)
1982 DP935 future beast
1969 911T rust bucket
1966 911 Buffum college car (1/2 owned)
Old 08-09-2018, 01:41 AM
Bucketlist's Avatar
I had an intermittent problem with intercooler seals until I added one of these^^^^, no problem since.
1981 SC Steel Widebody Outlaw in Pacific Blue and Artic White, 930/51 to 3.2l, K27 7006 Turbo, P&P Twin Plug heads, Twinfire Ignition, BLwur, Ruf Intercooler, Powerhaus headers, Zork, CIS Euro FD, 009 injectors, DOD, DP Lid, 044 pump, 930 4 sp LSD, Mocal 44 w/fan, LM2, Brembo, Retroair, Euromeisters.
Old 08-09-2018, 04:08 AM
T77911S's Avatar
i put a little grease on them to help the slide in. I have torn one putting the IC back on.
buy extras if you take it on and off a lot.
88 BMW 325is 200K+ SOLD
RACE CAR:: sold
Old 08-09-2018, 04:19 AM
beancounter
jwasbury's Avatar
I wouldn’t be surprised if its a quality issue. I recently had a oil return tube o ring failure on my 3.0 liter race car. Engine was professionally built about 2 years ago. The o ring just split open and started dumping oil on the headers.
Old 08-09-2018, 04:33 AM
It can't be moving on the turbo end, and the support is big enough.... has to be in the silicon coupler I'm using
Old 08-09-2018, 05:08 AM
full quack's Avatar
Send a message via Yahoo to full quack
Hey there Philip,
From your first photo, you can clearly see that the 2 parts are moving around a lot. The blemishes and burnishing marks clearly indicate that the 2 tubes are rubbing and moving around.
It's got to be your hose off the cold side of the turbo that is allowing movement.
Good luck!
Mark
Old 08-09-2018, 06:11 AM
Originally Posted by full quack View Post
Hey there Philip,
Good luck!
Mark
Those marks are the lube where the O ring was blown out... but I know something must be moving. I never had this problem before, now 2 O rings in less than 2 weeks...
Old 08-09-2018, 06:47 AM
