Dyno in Houston?
Hello I am looking for a shop to dyno my modded 930. The car is finally running excellent; however I want to see where I am at in terms of A/F ratio. It seems to be running a little too rich?
I am in Houston, any ideas? |
You’d be better off spending the money on AFR gauge. Pretty much a must for our cars and pretty easy to install. The hardest part is the post turbo exhaust bung. If you don’t weld most muffler shops will we’d it up for $40 or $50
81 Pacific Blue 930 Euro coupe slicktop on a strict diet, Rarlyl8 headers, Blowzilla turbo, Tial waste gate, Full bay I/C, Home made center out exhaust, Leask WUR, MSD 6AL, PLX wideband Wevo shifter, LSD. Next up, Cams, Heads and port work |
I have a bung welded in. Really looking for the "numbers" as I might sell the car later in 2019. These things help, i.e. dyno numbers, COA, compression and leak down etc. Plus I would like to tune it a little better if possible.
There are many Dyno's in the Houston area, if you Google "dyno tuning houston tx", there is a wide selection.
I'm in the NE (near the IAH airpot) and have used Slaters: Humble, TX Auto Repair Shop | Auto Repair Shop 77346 | Slater's Auto Works Whilst my car has a wideband, they will hook-up their own wideband and record the results. Not sure what they offer for tuning as I do all my own. HTH |
