930, how easy to change just 1st gear synchro?
Will be mating motor back to trans soon...
If this is relatively easy, would like to diy...
If a huge to do, probably won’t...
Thoughts?
Old 10-25-2019, 04:14 PM
depend how DIY you are, capable of remove and reinstalling the engine and trans yourself, then I think you should be able to do the synchro.
Old 10-29-2019, 08:21 AM
Motor and trans are out. Motor rebuilt. Just trying to figure out how much trans disassembly is involved. On the 914 for example, 1st gear synchro easily accessible...
Old 10-30-2019, 06:17 PM
I did mine years ago, but not too difficult. Changing syncro teeth on the gears is the biggest issue. There is a thread by Infraredcalvin that also references another thread about 930 transmission overhaul. If you are just taking off first gear, you will not have totally disassemble the gear clusters.
-Dennis
1977 930 Slant, MS3 EFI, Carrera intake, Twin plug, Powerhaus headers, Magnaflow muffler, Garretson intercooler, GTX3071R
Old 10-31-2019, 09:16 AM
Non User
infraredcalvin's Avatar
It’s much more involved than the 914 1st gear. If you go in, you might as well do 3rd while you’re at it... then again you might as well get all of them... BTDT
Infraredcalvin - AKA Pat
'76 Turbo Carrera #311 - Factory LSD, Sport Seats
‘71 914-6 GT 3.4L twin plug track car
'75 914 GT clone project
'71 914 track car, fresh 2165 FAT motor (for sale soon)
Old 10-31-2019, 03:54 PM
Mike Billings's Avatar
Here's a two-part 930 transaxle rebuild.
https://www.youtube.com/watch?v=rjUuIUrcZBg
07 911 Turbo - Pilot Sport Cup 2 ZP
96 Carrera 4 - Toyo R888r
73 911E - Hoosier R7 + twin 75's
92 Corvette - Nitto NT01
14 BMW X3 - Pilot Sport A/S 4
Old 10-31-2019, 04:01 PM
Smart quod bastardus
fredmeister's Avatar
for the amount of labor involved in disassembling the tranny just replace all the synchros. especially 1st and second. they see the most wear. you are goin got have to fully disassemble the tranny to do this job.
watch the video posted above......its great.
1979 930 Turbo....3.4L, 7.5to1 comp, SC cams, full bay intercooler, Rarlyl8 headers, Garret GTX turbo, 36mm ported intakes, Innovate Auxbox/LM-1, custom Manually Adjustable wastegate housing (0.8-1.1bar),--running 0.95 bar max
---"When you're racing it's life! Anything else either before or after, is just waiting"
Old 11-13-2019, 02:01 PM
I would rather be driving
jpnovak's Avatar
Hardest part is locking the gears to spin the nut off the gear stack. And then you need a puller for the end gear.
Are you familiar with 911/930 transmissions and how they operate internally? There are a few 901 and 915 tutorials out there for a guide.
The gear stack has to come out and separate from the middle case. Then the gears have to be removed from the shafts. Then the gears disassembled to remove the syncro ring. Also check the brake bands. Might as well address the slider and dog teeth while its apart.
I usually see 2nd and 3rd with most wear.
Old 11-13-2019, 04:31 PM
