Oil squirter
1. I was about ready to purchase new crankcase/piston squirters for my 930 efi 3.4 build. and I noticed from our host that they have an over size option. Should i get the over size or standard size?
2. I noticed my oil pump is a 964 oil pump, is there any difference between a 930 oil pump? thanks in advance |
For the squirters , remove them first and look at the condition of the hole. If the hole is good replace them with the nominal units.
There is a good thread on here somewhere, removal / replacement is relatively easy. https://forums.pelicanparts.com/911-engine-rebuilding-forum/975842-stuck-piston-squirters.html Also some aftermarket options available. |
The stage sizes are slightly different between the 964 and the 930 oil pumps, but the 964 pump has bearings, so it's a wash. The shaft size is different, too. So I'd stick with the 964 pump.
Steve G covered the squirters. Also, if you weren't aware, 930 piston squirter orifice size is larger than standard 911 squirters. |
It's a 914 ...
Isn't it more typical to test the squirters first rather than just removing/replacing all of them? |
test them .
do not remove them.
To which i responded "remove them first and look at the condition of the hole" Super easy to remove.......but i agree that it shouldn't be done without testing first....that would be silly !! |
when I removed mine they were a PITA. I had two the came apart and half was stuck in there. could not get it out.
I sent the case to the machine shop and let them do them.
