Location: Vilnius Lithuania (it's in Europe and it's not Russia)
3.3 turbo engine camshafts recommendations?
Hello, I’m rebuilding 3.3 turbo engine. And don’t know what type of camshafts should I go for. My current setup is:
Stock crankshaft Carrillo H rods 3.3 stock cylinders with JE 8,5:1 compression ratio Garrett gtx30 gen2 Aftermarket headers and intercooler. Dbilas dynamic are offering Duration: : 276°/272° Peak timing: : 108 Valve lift: : 10,7/ 9,8 That seems to be a bit to drastic for such low compression ratio. Please correct me if I’m wrong. What spec cams you will recommend for street application? |
Depends on what you want the car to drive like off boost and ultimate power. SC cams are popular for street driving, low RPM drivability. 964 cams are a good compromise (still mild), but more mid-range power. Since you are running a smaller turbo for a 3.3, you can probably get away with a slightly more aggressive grind (top end).
I have a pair of very low mileage SC cams by Webcam if you go that route.
Chris 89 930, 87 930, 86 930 Ruf BTR tribute, 89 Ruf CTR tribute |
Could someone tell me duration and valve lift of SC and 964?
I put SC in mine, wish I had the 964.
It's a 914 ...
Looking at the Dbilas dynamic cams, it's hard to tell whether their specs are seat timing (full duration), or measured at 1 mm or .050". That's important for making a valid comparison with what you'll see Web, DR, and others offering.
Mine has new Webb 964s.
SR 86 930 x: 62 356, 64 356, 76 930, 84 911 Targa, 85 ROW 911, 00 996, 07 Cayman S, 00 M5, 02 G500, 66 Shelby GT350 (x2), 64 Corvette. |
EFI vs CIS needs to be known too. You can use more cam with EFI.
Ken 1986 930 2016 R1200RS |
Brando
With the gtx30 the 964 might be better. The gtx30 should be way fast boosting and you wouldn’t need the sc cams. That turbo might even be too small?
Turbo powa! 1977 911s. it's cool |
I got a couple of these if you want...
A bunch of old race cars |
I just had a rebuild by TK and had Elgin SuperSC installed, which are in between SC and 964. Running in an EFI setup. They seem fine at the moment - good at all rpms, and I still need to get to a dyno for some ultimate fine tuning, so there is still more to be had I believe. Nothing on a track so cannot speak to performance other than on local roads.
It is hard to select without first hand experience ... best of luck with your choice.
Emery 1988 930 coupe - Silver Metallic TurboKraft 3.3L 8:1 CR, SuperSC Cams, GT35R, B&B Headers, TK intercooler, Tial WG, ARP, tecGT based phased sequential EFI & ignition, Wevo shifter/coupler, ...
I have same cams - got them from TK.
I don't have much to compare them to - I changed a few things at the same time. But I am happy with the range of performance of the beast. Pulls well once on boost, all the way thru the range. Off boost seems OK, but I try not to spend any time there, but around town I think it would be fine. Alan
83 SC, 82 930 (track) - Stock except for RarlyL8 race headers, RarlyL8 Zork, K27-7006, 22/28 T bars, 007 Fuel head, short 3&4 gears, NGK AFR, Greddy EBC (on the slippery slope), Wevo engine mounts, ERP rear camber adjust and mono balls, Tarret front monoball camber adjust, Elgin cams, 38mm ported heads, 964 IC. 380rwhp @ 0.8bar Apart from above, bone stock:-) |
