Banned
Porsche 911/930
Just had the SECOND failure of my water pump on my 991.2 GTS inside a MONTH. Googling seems to show that there is a serious problem with these items, revisions to the part haven’t solved it as some 992’s have had it. Not sure why I’m posting here really as there’s nothing you can do to avoid it but just a rant really. I’m so raged at such shoddy quality it makes me want to sell it - why suffer such crap reliability? If it had let me down like this whilst I was over in Europe thousands of miles away from home with my family alongside as I was twice this year I would be totally stuffed. So, beware that you could be stranded roadside at any time without warning with a problem that usually only happens with old knackered shopping cars. Brilliant.
Old 04-05-2023, 05:24 AM
I think you will have better luck over on rennlist.com. Pelican is a great resource but focused more on the older cars.
Good luck!
the third foot™ adjustable heel/toe pedal is back!
http://www.wingsaircooled.com
https://youtu.be/U0PZbc55gqw
Instagram: @wingsaircooled
Old 04-05-2023, 07:41 AM
Sell it. Get a 930.
'79 930 turbo RoW - Oak Green Metallic - k27-7200 Raptor - Kokeln Intercooler - RarlyL8 headers/muffler - Tial 46mm - 964 turbo WuR - Rebel racing bushings front/rear - ER Monoballs front/rear - ER adjustable spring plates - 29/23mm TBs - Vons level 2 - Raised spindles w/weld on racing bump steer knuckle -Wevo engine mounts - Rebel racing transmission mounts - Ruf speelines 17x9-10 - Classic retrofit electric A/C
Old 04-05-2023, 08:26 AM
908/930's Avatar
Originally Posted by JacobS911 View Post
Sell it. Get a 930.
Problem solved.
So what is failing, bearing failure or seal?
Old 04-05-2023, 09:13 AM
dos531's Avatar
Wouldnt have that problem with an air-cooled. You'd have a bunch of other problems instead.
'86 930 Guards Red - EFI MS3Pro, 80lb inj, 3.4, GT35R, Tial 46, Bosch 044, B&B Headers, 3.2 carrera manifold, Turbokraft Full bay IC
'12 Gallardo LP-570-4 Performante
Ducati 748R
Old 04-05-2023, 10:02 AM
DSM DSM is offline
DSM's Avatar
Great post. Made me burst out laughing. I needed a pick me up today..... Thank you!
Old 04-05-2023, 11:58 AM
908/930's Avatar
I did a quick search it looks like Porsche used a Glass loaded nylon pipe bolted to the pump and using a o ring to seal. I really wish auto manufacturers would stop using nylon crap everywhere or at least understand the expansion problems better. Nylon is about as stable as wood and water goes through it at about the same rate. Is this what failed on your car?
Old 04-05-2023, 02:24 PM
Banned
Good luck!
thanks chum. It’s on the Porsche extended warranty but it’s the unreliability that bothers me so, I never had any problems with Ferrari or Aston, only bloody Porsche
Old 04-05-2023, 04:20 PM
Perhaps an improper installation/fix? No manufacturer is without issues, but Porsche shares the top tier of the customer satisfaction food chain so most consumers are happy with their product. As noted Rennlist will likely flush out a few owners with a similar problem if it's a weak point.
Fortunately for you it's under warranty.
Old 04-06-2023, 03:28 AM
my friend, i believe you.
you have to write an email to mr. blume and tell him exactly this, it's inferior quality. he will answer you. i did that too
oliver.blume@porsche.de
Old 04-06-2023, 07:49 PM
