Alan L's Avatar
website query
Does anyone have the answer as to how to get the Pelican Parts website to accept your vehicle is a 930? It has a 'Make' section to the search function - but does not list the 930. Best I can do is 911. Which is fine for my SC but does not work for the 930. Would be useful to be able to search for 930 parts.
Regards
Alan
83 SC, 82 930 (track) - Stock except for RarlyL8 race headers, RarlyL8 Zork, K27-7006, 22/28 T bars, 007 Fuel head, short 3&4 gears, NGK AFR, Greddy EBC (on the slippery slope), Wevo engine mounts, ERP rear camber adjust and mono balls, Tarret front monoball camber adjust, Elgin cams, 38mm ported heads, 964 IC. 380rwhp @ 0.8bar Apart from above, bone stock:-)
Old 05-13-2023, 10:03 PM
Regards
Alan
You can easily choose it as "911 turbo", as in this pic :
-1977 911S Coupe, Mahle 3.4, single GTX3584 turbo, - G50 5 speed trans, Haltech 2500 engine management.
-1987 Carrera Coupe.
-2013 Carrera S PDK Coupe, factory Aero Kit. My DD.
-1987 928S4.
Old 05-13-2023, 11:09 PM
The Pelican software doesn't like ROW cars; either pick 1979 or 1986 for your 1982. I usually go with 1979. Same problem with Hagerty's valuation site for insurance purposes. I search out the Porsche part number via google, the dealer, or on-hand literature then plug it into Pelican to confirm alignment of my 1982 part(s) number with the 1979 cars.
Old 05-14-2023, 03:51 AM
Alan L's Avatar
Weirdly, I don't get that option.
Maybe DC66 has provided the answer.
Will try.
Alan
Old 05-14-2023, 01:01 PM
tops911's Avatar
I have an 82 930 and use 1979 for the search of buying parts. I have not encountered any issues when ordering parts.
1982 930, K-27, BL adj. WUR, Rarlyl8 Headers and Hooligan muffler, PK CDI, 22 and 30mm torsion bars, poly bronze bushings 30mm raised spindles and custom valved Bilstein shocks (by Elephant Racing), monoballs front and rear (by Rennline), Alton 17" Fuchs, Fred Cook fuse panel
Old 05-14-2023, 08:06 PM
Alan L's Avatar
I don't have any problem ordering parts. Just a mater of finding them. Often I search via my SC vehicle and see if it is 930 compatible. When coming to specific 930 parts, I could not pull up a 930 catalogue.
I will try entering under '79. looks like that will work.
Thx DC66.
Alan
Old 05-14-2023, 09:52 PM
