75 911 (930) wiring diagram - mainly headlight circuit
hello to all...have a 1975 911 in the shop. need wiring diagram for this vehicle. looking mainly for the lighting circuit. the left side parking lights are always on when battery is connected. we can remove the fuse for that circuit and the lights are still on.
this vehicle has an aftermarket alarm system installed and do not know if it has anything to do with this symptom. there are a lot of added wires, relays and switches under the dash.
any help with this matter will be greatly appreciated...m
Old 06-16-2023, 08:34 AM
Awesome! I've been waiting for another post from you guys.
Tutuapp 9Apps Showbox
Old 06-21-2023, 02:24 AM
proffighter's Avatar
If it's a german (or maybe also ROW) car, then it may be the fact, that in Germany you had to add parking lights LH or RH with turn signal switch, this circuit:
Roland
930 Turbo '81 Too many modifications to list
Old 06-21-2023, 04:55 AM
Feels like the turn indicator stalk needs to be carefully checked or.perhaps replaced.
Does the other side parking lights go on, when you switch the stalk to the other side with ignition off?
Old 06-21-2023, 12:47 PM
