Triangle of Death
Hey guys-
964 Turbo - but essentially close enough to 930 - How difficult (or possible) is it to replace the 3 seals in the TOD with motor in - and NOT removing the Fuel Distributor?
Thanks-
Brandon
'91 911 Turbo
'87 325i Convertible
'16 Audi Allroad
Denver, CO
Old 11-08-2023, 09:20 PM
Alan L's Avatar
I only know the 930, but it should be do-able. Just a matter of what peripheral crap you have to move.
Alan
83 SC, 82 930 (track) - Stock except for RarlyL8 race headers, RarlyL8 Zork, K27-7006, 22/28 T bars, 007 Fuel head, short 3&4 gears, NGK AFR, Greddy EBC (on the slippery slope), Wevo engine mounts, ERP rear camber adjust and mono balls, Tarret front monoball camber adjust, Elgin cams, 38mm ported heads, 964 IC. 380rwhp @ 0.8bar Apart from above, bone stock:-)
Old 11-09-2023, 12:41 AM
yeah I'm figuring/hoping to just remove the intercooler, move the ac compressor out of the way and remove airbox. Wasn't sure if there would still be a nut or something I wouldn't have access to...?
Thanks-
Brandon
'91 911 Turbo
'16 Audi Allroad
Denver, CO
Old 11-09-2023, 08:21 AM
Here is a link to a website and forum where they are discussing it in a little more detail...But not directly pertaining to a 964
https://www.impactbumpers.com/forum/index.php?/topic/35797-sc-triangle-of-death-leaks/
https://ponderingporsches.blogspot.com/2016/02/the-triangle-of-death.html
Old 11-09-2023, 09:41 AM
I lowered my engine about (911) about 3 inches to make it a lot easier.
Old 11-20-2023, 12:02 PM
Follow up
Ok I'm close - problem is there is a little black bracket that supports the corner of the fuel distributor that is keeping the breather cover from lifting off/over the studs. I removed three 13mm nuts but the bracket won't budge. I don't see a fourth. Am I blind? What am I missing?
EDIT Nevermind - got it. It actually was being held captive by the vertical stud off the FD.
Project now completed. We'll see how long til this area leaks again.
Thanks in advance-
Brandon
'91 911 Turbo
'16 Audi Allroad
Denver, CO
Old 12-29-2023, 03:13 PM
