valve adjustment 1987 930
Can the crankshaft be rotated by turning the alternator pully without removing the sparkplugs?
New fanbelt with 6 shims installed between pully half and tensioning cap. 1/4 inch deflection of fanbelt with ac belt removed. Thank you |
Yes, but you may need to add some extra tension on the belt - with your fingers. I find the RHS of the belt works better.
Alan
83 SC, 82 930 (track) - Stock except for RarlyL8 race headers, RarlyL8 Zork, K27-7006, 22/28 T bars, 007 Fuel head, short 3&4 gears, NGK AFR, Greddy EBC (on the slippery slope), Wevo engine mounts, ERP rear camber adjust and mono balls, Tarret front monoball camber adjust, Elgin cams, 38mm ported heads, 964 IC. 380rwhp @ 0.8bar Apart from above, bone stock:-) |
I cup my hand over wrench on the pulley nut to secure, and use my fingers to apply pressure on the belt (right side when facing engine) when rotating the pulley.
Just put the car in gear and use a broomstick between a couple of lug bolts to turn the engine over. I find it much easier.
Have to stop the other wheel from rotating ofc.
'86 no-sunroof 930 coupe: Emissions removed, FrankenCIS controlling eWUR, lambda, COP ignition. Tial f46P 1.0 bar spring, SC cams, K-27/29, lightweight clutch, TK Longneck intercooler, RarlyL8 headers and dual-outlet hooligan '14 Jaguar XK-R: Bullet proof windscreen, rotating number plates (valid all European countries), martini mixer, whatever you do don't press this red button! |
