Alan L's Avatar
fuel pumps on.
So my beast has developed a new issue since pulling the engine - twice in last couple of weeks. It used to be fine, but now the pumps are on with the key on - mostly. Sometimes not. It gets weirder. While checking the circuits I have found they are on with key on with the engine bay relay pulled. And even weirder, with the 14 pin plug OUT.
Which takes me to the frunk? I hadn't been in there while doing the engine out - other than battery disconnect.
So I can confirm the circuit from the pumps relay to the relay in engine compartment is complete. The o/boost circuit is complete (#7 pin at T14), the airplate circuit is complete (#8 pin at T14). Not that iot makes much difference because the pumps seem able to run without any of those things!!. WTF.
Thanks for any suggestions - my brain is fried with 930 stuff right now.
Alan
83 SC, 82 930 (track) - Stock except for RarlyL8 race headers, RarlyL8 Zork, K27-7006, 22/28 T bars, 007 Fuel head, short 3&4 gears, NGK AFR, Greddy EBC (on the slippery slope), Wevo engine mounts, ERP rear camber adjust and mono balls, Tarret front monoball camber adjust, Elgin cams, 38mm ported heads, 964 IC. 380rwhp @ 0.8bar Apart from above, bone stock:-)
Old 02-27-2024, 06:25 PM
Alan L's Avatar
After sleeping on it I concluded the circuit between the FP relays and the relay on the regulator board (they are connected to each other) must be earthing somewhere.
Then I found I could make them on/off by wiggling wires near the regulator board. At the point the pumps were on, I could find an earth track from the 30 feed to the regulator relay. That is hard wired back to the FPs. So that will be the cause - just have to find the aberrant wire. (And sort my clutch - which is fighting me also).
Hoping for a day off soon :-)
Alan
Old 02-28-2024, 10:33 AM
mark houghton's Avatar
That's a weird one Alan. Most definitely a short along the line. Now the hard part finding it.
Mark H. 1987 930, GP White, Wevo shifter, Borla exhaust, B&B intercooler, stock 3LDZ.
Old 03-17-2024, 10:15 AM
Alan L's Avatar
Well, I have found it - sort of. Had to remove the intake manifold to get enough access, but it was in the loom that runs along the side of the engine bay to the 14 pin plug. Pulling that clear required removing some stuff - including FA etc.
I found one bit that 'may' have been the culprit. The problem has not come back.
The next one to strike me down was the TTS failed.
Not much left to fail now.
Regards
Alan
Old 03-17-2024, 11:11 AM
