Hi there,
I'm reading alot on this forum and finally decided to turbo my beloved 1985 3.2 Carrera Targa. its my first Porsche and owned it now for about 3 years. My game plan : ECU VEMS thx @Raceboy Pulsar GTX 3584RS 0.63AR Oil feed from Turbokraft 930 J pipe Custom Exhaust with center outlet Tial F46P wastegate with 7PSI spring Siemens Deka 630cc injectors Small intercooler to fit under the original bonnet 2.5" piping (ebay special) I might add a 4 port boost controller to manage the boost (not sure yet) Wish me luck, will need it ![]() if anyone wants to follow on IG : 85_9_1_1_ the car : ![]() The engine atm:
Chain fence eating turbo
You’ll start out at 0.5 bar, but 1.0 bar is where the party really starts. It’s addicting. I’m up to 1.4 now and have ran 1.5 before for fun. Tires must be good or no traction at that point.
We ran our last 3.2 turbo conversion at .6 bar, with an intercooler.... There is tons of more safe power there, but client thinks it has pleny of power as it is....
Cheers
Turn3 Autosport- Full Service and Race Prep www.turn3autosport.com 997 S 4.0, Cayman S 3.8, Cayenne Turbo, Macan Turbo, 69 911, Mini R53 JCW , RADICAL SR3 |
First step in the build was to fit the turbo and fab the j pipe ...
So that the turbo goed trough the hole in the tin .. Some pics : ![]() ![]() ![]() ![]() Now the original exhaust goes back on, car to my garage to start the conversion. |
Kind of sleeper. Kind of not.
'79 930 Minerva Blue/Cork '98 993 Cabriolet Glacier White/Midnight Blue Fire - '91 C2 Targa Black/Tan |
well, the car is almost finished, i need to install the ic but is is running awesome atm..
0.5/ 0.7 bar boost . I want to thank @raceboy espacially for taking the time to tune the car and have the patience for all my questions. some pictures : Old vs new (deka 630cc injector) ![]() Vems stealth unit in place ![]() Check valve inplace, removed venturi for brake booster ![]() intake breather hose replaced by this small breather/filter ![]() injector in place ![]() Vacuum line(wastegate) ![]() Backside view ![]()
wastegate + screamer pipe
![]() sideview off the turbo intake side ![]() Oil feed line going thrue the tin ![]() Oil feed line hooked up-turbokraft (awesome quality) you need the 930 adapter to engine block to install this (expensive thrue turbokraft but ordered one online) ![]() engine view ![]() Turbo sitting nicely thrue the hole in tin..
Small video :
https://www.youtube.com/watch?v=tYR_itnbr-4 |
How did you attach intake to throttle body and plumb the idle valve?
Always learning. www.aircooledporsches.com.au |
Hey Michael, i attached it using a 90 degree elbow reducer.. 83mm to 63. Idle valve is plumbed with a quick tap 20mm connection. ![]() Btw guys, Michael here is truly a man with many knowledge, he has answered many questions that i had. He was helpful to me . |
Turbonut
Nice to see your car running great! Couple of observations though: first thing you should install proper air fitler
Not only due to dust entering engine (and severly reducing engine life) but the mesh actually flows worse than air filter.And secondly definitely proceed with intercooler install, intake temps will be skyrocketing when true summer arrives. May I ask why you removed brake booster check valve? Boost should not enter the booster..
'83 924 (2.6 16v Turbo, 530hp),'67 911 hot-rod /2.4S, '78 924 Carrera GT project (2.0 turbo 340 hp), '84 928 S 4.7 Euro (VEMS PnP, 332 HP), '90 944 S2 Cabriolet http://www.facebook.com/vemsporsche |
Calm Peep, calm 😉 ![]() Brake booster is not getting any boost thats why i installed a check valve it flows towards the engine not away from it . |
I think we need a longer video and maybe some in car footage!
Thanks for sharing. I’m at 1 bar with conservative timing and it’s a blast to drive.
Update:
Brando
Fun! But watch your intake temps
Turbo powa! 1977 911s. it's cool |
Yeah, that IC is pretty small for .7. I get that it fits under the stock lid. Nice install though.
Greg Lepore 85 Targa 05 Ducati 749s (wrecked, stupidly) 2000 K1200rs (gone, due to above) 05 ST3s (unfinished business) |
would 2 small fans help with IC/intake temps
