Happiest when Tinkering
mahles were on sale hard to pass up
" Porsche there is no substitute" I always liked that saying. Air cooled is the only way to go! 76 911 C.R.A.P. Gruppe #2 BIG time TURBO C.R.A.P. Bitz EFI/EDIS Now MegaSquirt 3 76 Blazer also restored by me |
Banned
I think that's a great platform to start with.
Jut got off the phone with the machinist and we have pretty much finalized the plans for this engine and it will be bulletproof top people are working on the part Pauter and dockerty are doing cams and connecting rods/rocker arms the heads will go out in a month or so for twinplugging then come back for reassembly at Noland's then it is just small parts acquisition an final reassembly to a long block. Just need money LOL. One note is I had 11 head studs broken off in the case and he told me 3 are out and it looks good for the rest to come out fairly easy it is taking time because he had to move his shop and the holidays but i am not in any hurry just want it done right.
![]() ![]() The tear down in progress the inside so far looks good after 15 years of running boost I suspect I spun a bearing so this 2.7 isn’t worth a rebuild so it will become a coffee table and the crank will be an end table |
![]() The cause of the failure has been found both intermediate shaft bearing were wiped down to the copper the mains and rod bearings were rough but still had babbit crank looked pretty good will make a nice end table. |
![]() All broke down the case is a mess and not worth a rebuild the crank and intermediate shaft bearing surfaces are scored. The only stuff maybe worth while are the con rods and the oil pump is rebuildable. |
Grappler
At this point might as well get some new rods anyway.
Grappler Know Gi / No Gi 1976 RSR Backdate (Turbo 3.2) |
![]() First part from the old engine repurposed as a lamp for the end table |
Hows the build going?
Kyle - 1980 RoW non-sunroof 911sc - 3.2 Turbo, Mahle P&C, Carrillo Rods, Megasquirt II (Fuel Only for now), re-geared 3rd and 4th 930 gearbox, 2350lbs |
The heads are broke down gone for twin plug the cams and rockers have been sent to get refurb and new profile the crank is checked and polished and the case is getting worked to get the head studs out. I am getting the new parts bought as money allows.
Banned
No Commitment, Just Pleasure: Connect with Local Ladies in Your Town
Find Women Who Want to Enjoy Life Tonight in Your City
Supreme Сasual Dating https://datingnow.site |
um....
Always learning. www.aircooledporsches.com.au See me bumble my way through my first EFI and TURBO conversion! https://youtu.be/bpPWLH1hhgo?si=GufVhpk_80N4K4RP |
Great Work!
![]() The finished end table |
![]() The first new parts! More on the way the turbo has to go back to turbokraft for repair looking for a box that will work now |
Most of the parts for the short block are on the way. Using a GT3 oil pump reaming the oil squirters out 10 thousands, the turbo going back to Turbokraft for repairs and some performance upgrades to support the higher output engine getting things set for twin plugging. Will post pics as I get them.
The cams, heads, and rockers al going to get machined
![]() ![]() ![]() Goodies are coming in more to come over the next couple weeks |
curious; do the arp through bolts call for the same torqye setting as factory?
I can look at the instructions and let you know edit: the torque spec is 25 ft/lb I think stock is 35 ft/lb
" Porsche there is no substitute" I always liked that saying. Air cooled is the only way to go! 76 911 C.R.A.P. Gruppe #2 BIG time TURBO C.R.A.P. Bitz EFI/EDIS Now MegaSquirt 3 76 Blazer also restored by me Last edited by gsmith660; 01-14-2025 at 02:10 PM.. |
