Happiest when Tinkering
The plan is to use the 915 while we shop for a G50 01 to swap out I am going to run the engine detuned until the swap then unleash the beast
" Porsche there is no substitute" I always liked that saying. Air cooled is the only way to go! 76 911 C.R.A.P. Gruppe #2 BIG time TURBO C.R.A.P. Bitz EFI/EDIS Now MegaSquirt 3 76 Blazer also restored by me |
Brando
It'll be great with .7bar.
Turbo powa! 1977 911s. it's cool |
.7 bar is where I was going
![]() New steering wheel
Banned
Cool motor build,, Gonna work on these small projects until I get the motor back.
![]() Assembly has begun first half head studs installed and stress checked working on the other half. |
![]() ![]() ![]() ![]() ![]() Major progress! Turbo repaired and on the way back to me |
![]() ![]() More goodies today thanks to Chris at turbokraft for the quick turnaround |
Not the prettiest weld but it will hold
![]() New 60 lb injectors Siemens deka |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() More assembly pics we have a short block! |
Cylinder heads by the end of the week real close to having a long block. Getting excited!
3.5 lbs of rotational load so the case and crank is straight.
Heads are done picking them up Monday P/Cs installed getting ready do volumetrics and set compression ratios. Cams and rockers will be done by Friday and on the way back to us. It’s getting done!
Good progress. Nice milestone to get that case buttoned up. What sealant did you use?
Ken 1986 930 2016 R1200RS |
![]() ![]() ![]() The heads are done! |
![]() Measuring deck height and volumetric measurements calculate C/R |
Banned
sweet.
![]() Love Gibbs oil cleaned up my intake the parts washer fluid started some sort of corrosion that I couldn’t get to stop until I put Gibbs on it.
![]() New injectors installed
