The more I think about it, it would be really cool to make a Speeduino based drop in solution for the SC. If you really tried to keep the budget in check it could be done for pretty cheap. Just managing fuel and leaving the ignition system alone would keep cost down. CIS works well but it doesn’t last forever and it would be nice to get rid of the restrictive air flow meter. I can’t imagine there would be much of a HP boost, but probably a little!
My thoughts were, an airbox that disposes of the original airbox, and which can adapt a throttle body with standalone ecu OR a holley sniper. I've run a sniper on the engine stand and it seems to work fine. There are others who are running them in 914 and work well. ignition can be taken care of by the original distributor and CDI. If you went standalone, you could get fuel rails and injector adaptors from BITZ. Someone made this manifold to run a holley carb and a turbo: i bought the intakes but not sure how I would go to get this replicated. https://youtube.com/shorts/IkXNI71DzGo?si=EwuPdlZLQ9bf-6Pf And here it is running (this had a BIG camshaft). https://youtu.be/rLlUsFeiOVw?si=XJMg14Jgdiu4xf6s |
This is really super cool, that you designed and 3D printed your own intake manifold at home! This was unthinkable just a few years ago when Stratasys kept the industry locked up with their patents. Which PPA did you end up using, and how are you going to seal it up? Is the nylon glue going to be enough or did you design the interlocking pieces to use some form of gaskets? Following closely as you are blazing this trail, as a fellow printing nerd. :D |
Thanks! I used the "Siraya Tech Fibreheart PPA-CF Core" filament. It has the carbon concentrated in core so the layer bonder is improved. I think this is the strongest PPA right now and it's pretty cheap too.
The goal with the bonded seams was to have the glue in shear as much as possible. The two halves of the main body have a huge overlapping joint and should be crazy strong. The runner to main body joints incorporate tabs that go across the bonded joint. This gives me some good shear surface for the glue, but honestly, the flat faces of the joint would probably be strong enough. I will share photos of it being glued together. I first need to print TPU scrapers that I will pull through the runners to clear up and glue the oozes inside the runner. It would be impossible to remove once cured. |
Sharing an intermediate’ update. Not too much newness but some progress.
The manifold is coming together with brass inserts and mounting of the MAP sensor and IAT sensor. The IAT is from an Audi 1.8T…a good sensor. Also, after three tries I finally successfully printed the back cover. This one is tricky bc there’s a lot of support material that was impossible to remove on my first tries. Even the Bambu PA support material which is made for this was impossible to remove. I ended up using ASA on the support interface and it worked perfectly. A huge unlock for printing in nylon. The throttle body brass inserts mount from the back. They are crazy strong, but this is a spot where I wanted to make sure they couldn’t pull out. http://forums.pelicanparts.com/uploa...1759878264.jpg http://forums.pelicanparts.com/uploa...1759878264.jpg http://forums.pelicanparts.com/uploa...1759878264.jpg http://forums.pelicanparts.com/uploa...1759878264.jpg http://forums.pelicanparts.com/uploa...1759878264.jpg |
Looking very nice. Is that a 74mm throttle body?
Yes, it's a 74mm. Way bigger than I need but also very cheap...
This is very cool and I have been wanting to design a Nylon intake myself.
Great work! Here are the ITB adapters I designed years ago that were physically machined in China from a fellow member. Looks like you have the same interface: http://forums.pelicanparts.com/uploa...1759950444.jpg http://forums.pelicanparts.com/uploa...1759950460.jpg |
Nice! I reverse engineered mine from a 3D scan of the stock manifold. The injector angle was a tricky part.
A bit of an update. I decided I should do a test torque of the runners before gluing everything together. The result, total failure. Crapola... I torqued them early on but this time I used the proper plastic intake spacers. I think what happens is that the intake spacer is soft and deforms under the 3,000 lbs of clamping force for each of the mounting bolts. The compliance of the spacer transfers a huge amount of load across the full face rather than just below the bolts. The plastic flange has basically zero flex so it cracks. The plastic flange would work on a metal surface but it's not going to work on the soft plastic spacer. So...the plan is to have the lower sections 3D printed from Aluminum and then bond them to the nylon intake. It's an extra $350 and a little annoying. I think I'll take a break from this and get the turbo plumbing in order. |
I hit the same point when doing my 3.0 EFI conversion, the plastic adapters just weren't up to it so had them 3D printed in aluminum. Pretty easy for my application since I was already using the 964 manifold and factory gaskets so I didn't have to make many design changes to just bolt on the new ones. The amount of material does significantly impact the price though, so for mine I found I could get away with a much thinner flange overall with just adding more thickness at the bolt hole with a healthy chamfer for support. http://forums.pelicanparts.com/uploa...1760019773.PNG |
Beautiful part. Love it. My adapters are much heavier weight unfortunately bc I designed them to be plastic. My CAD model is such a mess and Fusion 360 is quite weak in terms of parametric referencing. Changing the flanges (the first features in the model) isn't an option anymore!
Yeah I use Fusion too so I feel your pain, keeping things neatly parametric is pretty much impossible for anything other than super basic parts. But yeah, juice probably isn't worth the squeeze on that.
I'll be following along though, what you've got so far is super exciting! |
It’s been a minute and the manifold is just about ready.
The 3D printed aluminum parts include the intercooler end caps, intercooler wedge, Porsche badge, and intake flanges. After the plastic failed I went with printed aluminum flanges that are bonded to the intake with a large overlapping area. The intercooler end caps are bonded to the cores using DP420. The cores with end caps are then bonded into the cartridge assembly using MA8110. Overall the design got pretty complex as it developed. Not ideal, but I work to keep things very stout. I’m feeling good about it. Next step is the finish and paint it. I’ll used a textured black. http://forums.pelicanparts.com/uploa...1762128163.jpg http://forums.pelicanparts.com/uploa...1762128163.jpg http://forums.pelicanparts.com/uploa...1762128163.jpg http://forums.pelicanparts.com/uploa...1762128163.jpg |
I wanted to do the final bond with it bolted to the engine which meant that I could not get to the glue the squeezed out in the runners. It took some time but these joints are perfectly smooth now.
http://forums.pelicanparts.com/uploa...1762128364.jpg http://forums.pelicanparts.com/uploa...1762128364.jpg http://forums.pelicanparts.com/uploa...1762128364.jpg |
The intercooler cartridge is primarily bonded together. The intercooler cores feel a little small to me, but they are rated for 500hp so they should cool the charge down enough.
The outlet port is at the top edge of the core to keep air from getting trapped. The wedge in the middle helps to divide the air but its primary purpose is to brace the intake manifold. It would want to balloon out but the retaining bolts keep it locked together. My leaf blower flows about as much air as the engine does at 4,000 rpm. The intercooler and intake manifold together showed a pressure drop of less than 1 in H2O or about 0.03 psi. Crazy. http://forums.pelicanparts.com/uploa...1762128793.jpg http://forums.pelicanparts.com/uploa...1762128793.jpg http://forums.pelicanparts.com/uploa...1762128793.jpg http://forums.pelicanparts.com/uploa...1762128793.jpg http://forums.pelicanparts.com/uploa...1762128793.jpg http://forums.pelicanparts.com/uploa...1762128793.jpg |
Gasket makinghttp://forums.pelicanparts.com/uploa...1762129131.jpg
http://forums.pelicanparts.com/uploa...1762129131.jpg http://forums.pelicanparts.com/uploa...1762129131.jpg http://forums.pelicanparts.com/uploa...1762129131.jpg http://forums.pelicanparts.com/uploa...1762129131.jpg http://forums.pelicanparts.com/uploa...1762129131.jpg |
| All times are GMT -8. The time now is 02:06 PM. |
