short bell in a 80 SC
still weighing my options.
The long bell 4speed transmission and the g50 are off the table way to many modifications to stuff in an SC.
what exactly needs to be done when putting a 75-77 short bell 4 speed in an 80sc wide body.
thanks in advance regards Ned
i would also be interested to see a gear ratio chart comparing the short bell stock gears with a 915 1980 row 5 speed.
Old 09-23-2024, 04:38 AM
gearhead
If you can find a short 930 for sale, it will be big money. It’s much cheaper to shorten a long 930.
1974 914 Bumble Bee
2009 Outback XT
2008 Cayman S shop test Mule
1996 WRX V-limited 450/1000
Old 09-23-2024, 05:48 AM
didnt know that was an option ....if you shorten what mods need to be done to fit it to a non turbo chasse ?
Old 09-23-2024, 07:14 AM
gearhead
There are a ton of threads about this if you search. The short answer is a machinist needs to remove 1.1”.
1974 914 Bumble Bee
2009 Outback XT
Old 09-23-2024, 07:52 AM
lake wales fla
Dan Barnes out of Vegas can shorten the Mainshaft and Bell housing for you.
As far as what’s needed for the conversion you will need a 245 mm flywheel for 80 or later 3.3, a pressure plate, disc and TOB for a 75-77 3.0 turbo. You will need 85-89 915 108 mm one piece axles and a modified trans crossmember. You can either find a used 930 shifter assy or use your stock shifter housing and install 930 shift lever and hardware. The 915 shifter can be modified to work but the throw is different and it is a pain to get right. Shift rod, shift coupler are the same on SC as they are 930. It’s been a few since I have done any but IIRC the clutch cable should also work with no issues.
Richard
Old 09-23-2024, 08:05 AM
Richard
Thanks Dan
Old 09-23-2024, 08:55 AM
Ryan_Cunningham's Avatar
Would be interested in this as well. I have a SBH 930 in my 1972 that is going to be receiving a G96.50 and 3.6 Turbo engine from a 2001 Turbo, at some point in the futute.
But I'm looking at putting a stronger engine in my 1981SC which has its stock 3.0 and 915. I'd consider throwing the four-speed in the SC if the gear ratios were right.
"Purists are the Karens of motorsports.
IG - Iron_Dad_Moto
1972 Porsche 911 - Long Term Project. 3.6TT/G96.50
1981 Porsche 911SC - In Progress.
F/A-18C/D, F-15C, F-35B/C
Old 09-23-2024, 09:34 AM
Brando
quattrorunner's Avatar
Spec books show what you want to see. There are threads on this as well.
Short answer is 915 1st is not useable as a sporty gear everything just happens too quickly, 930 1st gear is great as well as 2nd and third. 915 ratios other than 1st is awesome. but it finishes with redline in 5th with plenty of performance left on the table.
The 930 is great till it's not in 4th. You really do need 400hp minimum to ring out the 930. 500+ if you want redline if not more than 500hp. 7200 rpm gives you 200mph if I remember correctly.
Turbo powa!
1977 911s. it's cool
Old 09-25-2024, 09:09 AM
Brando
930 4th gear is a great highway cruiser.
Turbo powa!
Old 09-25-2024, 09:10 AM
flat6pilot's Avatar
Porsche Gear calculator here:
https://retro-sport.com/calculator/porsche
You can compare how the 915 and 930 4-speed looks. At the track with 300-350hp, 4th gear with a 930 box is absolutely useless.
I'm re-gearing 3rd and 4th in my 930 box to get it a bit more useable at the track but with some compromise on the street, too.
Here's what I went with on 3rd and 4th:
3rd gear 27 to 26 0.962962963 112mph (@ 6k)
4th gear 30 to 23 0.766666667 141mph (@ 6k)
4th is much closer to 5th in the 915. I'll keep my redline at or below 7k.
Kyle
1980 911sc 3.2 Turbo, 930 Trans
2006 BMW 330i 6mt (DD)
Old 09-25-2024, 11:45 AM
Brando
That's cool.
Turbo powa!
Old 09-25-2024, 02:18 PM
I believe Patrick Motorsports also carries the flywheel and clutch package for this combination.
Old 10-12-2024, 11:31 PM
gearhead
Patrick is a manufacturer with a full machine shop and can shorten the bell housing and sell you all the right parts for fitment. Not so much the guy in Vegas. I’ve seen a couple really bad bore repairs out of that place recently.
1974 914 Bumble Bee
2009 Outback XT
Old 10-13-2024, 06:41 AM
that's interesting... he is quite vocal about his quality/ability on his Instagram and Facebook accounts.
Always learning.
www.aircooledporsches.com.au
See me bumble my way through my first EFI and TURBO conversion!
https://youtu.be/bpPWLH1hhgo?si=GufVhpk_80N4K4RP
Old 11-11-2024, 12:41 AM
