Flynt's Avatar
Engine harness replacement - 76 930
Hello everybody.
Is it possible to replace the engine harness on a 76 930 with the engine still in the car? I know it's a pain to route under the intake manifold.. I'm thinking it can be done with a partial engine drop and raise the intake manifold up to clear? Anybody ever accomplished this, or should I just pull the engine?
Old 11-18-2024, 10:13 AM
I'd just pull the engine. It's not that much work and in the end SOOOOO much easier.
'86 no-sunroof 930 coupe: Emissions removed, FrankenCIS controlling eWUR, lambda, COP ignition. Tial f46P 1.0 bar spring, SC cams, K-27/29, lightweight clutch, TK Longneck intercooler, RarlyL8 headers and dual-outlet hooligan
'14 Jaguar XK-R: Bullet proof windscreen, rotating number plates (valid all European countries), martini mixer, whatever you do don't press this red button!
Old 11-18-2024, 12:04 PM
Brando
quattrorunner's Avatar
Pulling the engine is easy even if you don't have special lifts or special tools.
Turbo powa!
1977 911s. it's cool
Old 11-18-2024, 01:14 PM
Pull the engine!
Old 11-21-2024, 02:26 PM
Ingenieur
You have to remove the air filter housing, intercooler, upper intake, CIS lines, lower intake, fan strap, and pull out alternator far enough to get to the alternator terminals.
All of that has to be done whether the engine is in or out. If you have the jacks, engine out is probably easier, but the last one I did was with the engine in.
Old 11-21-2024, 08:41 PM
Flynt's Avatar
Yeah, thats the verdict I was expecting. I mostly didn't want to do it on jackstands again. Just another reason to wrap my other car up so I can use the lift! Thanks for the input, everybody.
Old 11-22-2024, 11:57 AM
