WydRyd's Avatar
Question JET HOT 2000 Coatings?
Fellow turbo junkies, what do you guys think about the JET HOT 2000 header coatings?
Is it worth spending the extra cash on this process to reduce engine bay temps?
I presume the actual spool-up improvement would be minimal, but it may be worthwhile just to have a cooler engine bay and reduce heat soak in our intercoolers?
I've heard from certain tuners that it may accelerate cracking in the joints around the header? Is this more prevalent in track cars, or street cars?
I've also been told NOT to coat the inside of the headers, as the coating could potentially flake off and ruin the turbo's turbine?
What do you guys think? Worth the effort or not?
I've got a set of GSF S.S headers (no heater boxes) which I'm intending to use with a Garrett GT35RBB turbo and free flowing Magnaflow single in/out muffler.
Merv
'89 911 Turbo Cab
Protomotive MAP ECU, Twin Plugged Heads, GT2-EVO CAMs, 3.3L fully finned P&C's, ARP fasteners, C2T head gaskets, Titanium Retainers, Turbo spec valves, springs & guides, 964 splash valves, GT35R BB turbo, GSF Stainless Headers, Magnaflow Exhaust, Full bay Intercooler, TiAL 46mm w/gate, TiAL 50mm BOV, Apexi AVC-R EBC, SPEC Stage3+ Clutch kit, Crane CDI Ignition
Old 11-01-2006, 09:29 PM
Me like track days
Craig 930 RS's Avatar
Why would you *ever* want to contain heat in headers?
To add more heat to an already taxed turbo?
Skip that stuff -
- Craig 3.4L, SC heads, 964 cams, B&B headers, K27 HF ZC turbo, Ruf IC. WUR & RPM switch, IA fuel head, Zork, G50/50 5 speed. 438 RWHP / 413 RWTQ -
"930 is the wild slut you sleep with who tries to kill you every time you "get it on" - Quote by Gabe
Movie: 930 on the dyno
Old 11-01-2006, 09:38 PM
Skip that stuff -
Because heat drives the turbo charger not pressure like so many think.. Look at allot of tuners the wrap their headers and wastegates to keep as much heat as possible in there. it does result in faster spool ups and is a proven factor in many dyno runs
Ben
89 944,85.5 944
914-6 2.4s GT tribute.
914-6werkshop.com
Old 11-02-2006, 06:44 AM
oh but to answer the question this is very common on Hi porformance applications but there is some risk that it could flake off
Ben
89 944,85.5 944
914-6werkshop.com
Old 11-02-2006, 06:45 AM
Me like track days
Heat driving turbos etc - great in theory and partially true in practice - but really......skip it on our cars. The downsides are numerous.
Old 11-02-2006, 07:29 AM
its not theory it is proven. I will search more I did find one picture but not the best..
Ben
89 944,85.5 944
914-6werkshop.com
Old 11-02-2006, 08:08 AM
here is another not of a porsche but same principle
Ben
89 944,85.5 944
914-6werkshop.com
Old 11-02-2006, 08:16 AM
Me like track days
Let's hear some success stories form actual turbocharged Porsche 911 chassis cars - with quantifiable results.......Bueler? Anyone?
Old 11-02-2006, 08:43 AM
Actually if one coats the headers and turbine housing of the turbocharger you will contain the maximum latent energy available. As a result the rotating assy (turbine wheel) will start spinning sooner-hence lag reduction. Typically with good coatings one can see 200 RPM reductions in lag.
As stated before, NEVER coat the inside of the headers or turbine housings. You will destroy your turbo in a short period of time. Please have this instruction in writing. Many times the coating company fails to heed the verbal instructions....
Kevin
Old 11-02-2006, 08:48 AM
Me like track days
Cool to see Kevin on this board now. He makes THE turbos for our 930s.
Kevin - What is your take on wraps?
Coatings on stainless headers (such as B&B) ......?
A few local guys have horror stories about the coating stuff flaking off. The wraps also hide the inevitable header cracks -
Wonder if it is worth 200 rpms, Kevin would know.
Old 11-02-2006, 09:01 AM
Wrap are not good in climates like the Pacific NW where we have rain.. Any condition where water will hit and soak the wrap will cause corrosion. Welds will fail. I have seen my share of turbine housings that have been wrapped, and most of the time I just toss the housings into the scrap bin.. However, for a race prepped only car, wraps have done well. Provided that there is no rain.. All in all, ceramic coatings by a well known company, Swain, JetCoat.. are cheaper and if the headers and turbine housings are prepped good, you have good results..
Results are less than favorable if one uses used parts vs new stainless and high nickle turbine housings.. It also doesn't warrant one coating just the headers, and not the turbine housing.. It is the turbine housing that we want the concentration of heated energy.
Another side note... Wrapping turbine housings do cut the life-span out of the turbine side sealing rings.. The heat tends to prolong the heat soak. It is minimalized if one had water cooled bearing housing, but that out of the picture in our application.. Heat radiating into the turbine shaft and bearings from the insulated wrap is NOT good and can suck out 50% of the life of your turbocharger..
Kevin
Old 11-02-2006, 09:22 AM
Me like track days
Excellent. Thanks a ton, Kevin.
Old 11-02-2006, 09:26 AM
You say that like a "told you so" when in reality we were both were answer it correctly just variations.
Don't know what that was all about But The answer was Yes and No flat and simple
Ben
89 944,85.5 944
914-6werkshop.com
Old 11-02-2006, 09:32 AM
Me like track days
You have a great internet imagination, mb...
I just appreciate the truth and especially the complete no-bull***** answer from Kevin.
You started with:
"Look at allot of tuners the wrap their headers and wastegates to keep as much heat as possible in there etc"
Kevin simply gave us a well rounded answer, take it for what it is.
Old 11-02-2006, 09:35 AM
No imagination Maybe Just a perception I see from the posts..
I can tell You that the heat energy is what drives the turbo but of course more heat will end its useful life much quicker it still is the driving factor none the less. This is the reason so many want as short of exhaust track as possible to keep the heat in there before it has a chance to dissipate threw the metal. So sometimes these tuners are using wraps etc. I for one am not but the question was can it be done YES it can. Is there potential problems yes just like using aluminum rods in dragsters but benefits.
None the less craig No hard feelings just trying to answer as completly as possible as I do have something to share on the subject..
Ben
89 944,85.5 944
914-6werkshop.com
Old 11-02-2006, 09:42 AM
Me like track days
Right on.
I wanted to clear up misconceptions about "coatings and wrap = good"
When in fact there are varying degees tha Kevin helped us out on.
Peace out!
Old 11-02-2006, 09:46 AM
yup same page !!!!!!!
Ben
89 944,85.5 944
914-6werkshop.com
Old 11-02-2006, 09:47 AM
7.0:1 > 11.3:1 > 7.0:1
I've been around. Never heard this before:
Can you elaborate on this Kevin? What damage occurs in a short period of time? (Flaking, eroded turbine tips...?)
Jim
Old 11-02-2006, 11:44 AM
Me like track days
This.
Old 11-02-2006, 11:51 AM
The "coating company" can not etch every nick and cranny inside the header.. Nor can they clean/etch the interior of a turbine housing. You have to have a mechanical bond on every surface. The ceramic coating flakes off and makes contact with the turbine wheel. With a wheel that can turn 140-160K RPM it doesn't take much to incure FOD (foreign object damage) to the turbine blades. The removal of metal from impact will greatly effect the balance of the rotating assy. Accelerated bearing wear will occur.. After this, you get contact between the rotating wheel assy and the housing on both sides of the turbocharger.. And yes, I have seen this happen many times..
Old 11-02-2006, 11:54 AM
