77 930 msd 6al install
hey guys new to this forum looks like some pretty sharp dudes on here.I am working on a 77 930 turbo installing msd 6 al I have spark but no fuel (dont think I am triggering the fuel driver correctly )does anyone who has done this before have a wiring diagram and do I need to still keep the CD box in the system(might be a problem I think box is bad).any advise is wanted
thanx in advance Matt |
The 6AL replaces the cd box and the 6AL has nothing to do with fuel. If you search Pelican 911 tech forum or Rennlist Turbo forum you will find wiring instructions.
thanx David ,I stil cant find which color wire goes to factory tach on the 77 ?
Matt |
If I remember correctly the 6AL has a violet wire, which goes to the black/violet stripe wire that runs to your tach but you may need the "MSD tach adapter"
Here is a diagram
http://forums.pelicanparts.com/uploa...1162819470.jpg |
thanx guys I was thinking it was the black and purple was to the tach hooked it up and no tach so looks like a tach adapter from msd thanx to all
Matt |
| All times are GMT -8. The time now is 06:14 AM. |
