-   911 / 930 Turbo & Super Charging Forum (http://forums.pelicanparts.com/forumdisplay.php?f=222)
-   -   Breaking up at boost (http://forums.pelicanparts.com/showthread.php?t=313159)
steven polaski 11-04-2006 08:59 AM
I just got my car back from a year long body restoratuion, It breaks up a little under boost. It has new plugs,wires,distr cap . All new injectors and so on. Do you think the computer needs time to figure things ? I am putting on a fuel enrichment gauge to see what going on.
AFJuvat 11-04-2006 10:41 AM
Sounds like your fuel mixture may be off - put a gauge on it and see what you get.
Are you running the stock US version CIS?
AFJ
F350Lawman 11-04-2006 12:27 PM
Mine seems to crackle a little under boost as the weather gets cold. I think the abundant suply of cool, dense air might overwhelm the fuel supply if you have some mods with the stock fuel setup.
I am no expert ...just following a common sense hunch???
steven polaski 11-05-2006 05:18 AM
It seems to run better as it warms up so I think it is just blowing out cobwebs. I also found a loose front fuel pump relay cuts out a little this could be the problem.
steven polaski 11-05-2006 07:24 AM
o.k. just pulled over by state police, asking what the rush was told him I had boost issues he told if he catchs me again i will have legal issues. On the good side boost comes on nice now.
beepbeep 11-05-2006 03:21 PM
probably just a sticky CIS plate...happends if it sits still for a year. Mechanical stuff, you know ;)
WydRyd 11-05-2006 05:09 PM
Re: Breaking up at boost
Just FYI, I don't believe the older pre-89 930's had a computer as such... it's all mechanical fuel injection.
steven polaski 11-05-2006 06:08 PM
mine has a dme box under the seat
beepbeep 11-06-2006 01:08 AM
You have CIS, thus no computer-controlled injection. 930 never had EFI.
Thing under your seat might be a piece of lambda-regulating circuitry. I gues you have catalyst-equipped car?
