After market intakes....your .02
I have beem searching for something better than the monsterous access blocking heat sink that I see the stock intake housing as being.
I have found three different ones and was hoping for some education from all you more knowledgable 930 guru's out there....what's do you guys think about them? Here's SuperTec's: Here's a very similar one I found on the 9XAUTO dot com website: and finally the Fabspeed intake... I have my own thoughts and opinions on each one but with the intention of seeing if I am at least pointing the right directiion in my thinking, let me know what you all think..... fire away !!
Johnny Riz 1973 911 Custom Euro 3.2L "Sports Purpose" '10 Subaru WRX-STi Hatch - modded. RGruppe#152 Early 911S Reg.#335 |
+ lurking - contributing
These aftermarket air filters biggest benefits are easier access to idle speed & mixture adjustments. I think performance improvement is negligible, it has been debated on other threads. Weight savings may be three pounds.
I used a hacksaw and cut out a large section across the hinged lid on my stock air filter housing. This retains the use of the stock Mahle filter. The sharp edges were turned in and adjusted to not interfere with the A/C hoses.
87 930 96 BMW M3 Coupe 89 951 08 Astra H Peugeot moped |
Forced Induction Junkie
What William said.
None of the intake tracts listed, do anything to smooth the flow into the CIS metering plate area. I think you may lose a few HP compared to the factory air box.
Dave '85 930 Factory Special Wishes Flachbau Werk I Zuffenhausen 3.3l/330BHP Engine with Sonderwunsch Cams, FabSpeed Headers, Kokeln IC, Twin Plugged Electromotive Crankfire, Tial Wastegate(0.8 Bar), K27 Hybrid Turbo, Ruf Twin-tip Muffler, Fikse FM-5's 8&10x17, 8:41 R&P |
Crotchety Old Bastard
You can make this one yourself for ~$20. If you don't like it you're not out much.
RarlyL8 Motorsports / M&K Exhaust - 911/930 Exhaust Systems, Turbos, TiAL, CIS Mods/Rebuilds '78 911SC Widebody, 930 engine, 915 Tranny, K27, SC Cams, RL8 Headers & GT3 Muffler. 350whp @ 0.75bar Brian B. (256)536-9977 Service@MKExhaust Brian@RarlyL8 |
Thanks for all your help guyz....also I went over to rennlist and did a search....nice info there...
cheers
