930turbo's Avatar
Boost enrichment delay
I know I've seen information on RPM triggered boost enrichment delay on this forum before, but I can't seem to locate it now. Once upon a time someone out there posted dyno results demonstrating the OEM over-rich condition in the early stages of manifold pressure and how it was resolved by a delay swith to block the pressure signal to the WUR until about 4000 RPM - I think. Does any of this sound familiar?
Old 02-04-2007, 07:31 AM
A fellow Pelacanite
NathanUK's Avatar
It may have been on Rennlist. Try searching for "Brian Leask" or "solenoid"
1981 UK 930. G50/01 shortened, 964 3.8RS Fibreglass Body Kit, 18" Alloys 8.5" F & 10" R, 225's F & 285's R, Special Colour Metallic Blue Paint, FIA Sparco Evo's, A/C and Air Pump removed, Electronic Boost Controller, GHL Headers, Tial46 WG.
Fitting - New service kit.
Needs Fitting - Innovate XD-16 Kit, Kokeln IC. Stephen's K27 HFS, EVO Intake Assy & his Modded USA Fuel Head.
1983 UK 911 3.2 Carrera Sport Coupe. Black, Black Leather with Red Piping, Black Alloy Gear Knob, K&N Air Filter Element, Turbo Tie rods.
Needs Fitting - K&N CO Sensor, Round A/F Dial Gauge, Factory Short Shift Kit.
http://www.danasoft.com/sig/Iamnotanumber.jpg
Old 02-04-2007, 03:05 PM
Crotchety Old Bastard
RarlyL8's Avatar
Leask has a device that performs that function.
I would think it to be more advantagous to delay enrichment to a preset boost level instead of a preset rpm. As you know boost onset is a different rpm in different gears and ambient temperatures. Something like 0.4bar might be a good preset for boost reading delay at the WUR.
A quick data log of A/F ratios throughout your operating rpm range will tell you when it hits under those conditions. You can count on greater lag when the intercooler heat soaks or while driving on a hot humid day.
A simple hobs switch will perform that function.
I am going to do this myself very soon and will post all the dyno runs.
Old 02-04-2007, 08:43 PM
since we are running too rich in the mid-rpm range, would it be beneficial to dial in more boost in those rpms via a ebc?
Old 02-05-2007, 08:01 AM
A fellow Pelacanite
NathanUK's Avatar
As the CIS meters the air with a flap it will try to compensate for any extra air being forced into the engine. So I doubt it.
Old 02-05-2007, 02:59 PM
but won't running higher boost in those "too rich" rpm range will actually lean out the afr curve?
Old 02-05-2007, 03:11 PM
A fellow Pelacanite
NathanUK's Avatar
I don't know for sure. I wouldn't think so.
Why do you think it would ?
Old 02-07-2007, 02:51 PM
Ken911's Avatar
Brian Leask has it available with is adjustable wur. http://members.cox.net/930wur/
88 turbo Guards red Targa slant nose, and yes I am a horsepower junkie, 3.4liter,7.5 to 1 JE pistons, Adjustable WUR, Imagine fuel head, 1 bar waste gate headers,allthe cis toys. Now apart to become the next EFI monster. fabbing my own intake, headers Individual throttle bodies, MS-3, pauter rods, Xtreme twin plugged heads, gt-2 evo cams cop's.
2019 Silverado 6.2L
Old 02-07-2007, 05:40 PM
