vmisquez's Avatar
Hunting Idle speed
Hi all,
Before I start looking for vacuum leaks just wanted to check if anyone has fixed a problem where warm idle speed gently sways about 9K.
The car is 1988 930 with closed loop CIS (stock).
Thanks for your time.
V.
Old 02-06-2007, 11:42 AM
WydRyd's Avatar
I think your best bet is to verify your CO% at idle and then start looking for vacuum leaks
Merv
'89 911 Turbo Cab
Protomotive MAP ECU, Twin Plugged Heads, GT2-EVO CAMs, 3.3L fully finned P&C's, ARP fasteners, C2T head gaskets, Titanium Retainers, Turbo spec valves, springs & guides, 964 splash valves, GT35R BB turbo, GSF Stainless Headers, Magnaflow Exhaust, Full bay Intercooler, TiAL 46mm w/gate, TiAL 50mm BOV, Apexi AVC-R EBC, SPEC Stage3+ Clutch kit, Crane CDI Ignition
Old 02-06-2007, 08:09 PM
vmisquez's Avatar
Thanks WydRyd, I checked and found a leak in the exhaust plumbing. I'm not sure how this happened but I do know the leak/disconnect is after the O2 sensor. Looks like some hard driving caused the disconnect.
I'm sorry id this is not clear I just got the car and have not yet had time to go through the manuals.
Thanks again. I'll get this fixed before I attempt to smog test the car in CA.
V.
Old 02-06-2007, 08:39 PM
