-   911 / 930 Turbo & Super Charging Forum (http://forums.pelicanparts.com/forumdisplay.php?f=222)
-   -   adjustable boot knob? (http://forums.pelicanparts.com/showthread.php?t=333655)
h20cooled7 03-04-2007 11:29 AM
adjustable boost knob?
i think i have a adjustable boost valve under the left side of my dash. how do these work, when i fool with it it doesnt seem to make a difference.
pete
squerly 03-04-2007 04:25 PM
Re: adjustable boot knob?
pete
What makes you think it's an adjustable boost knob verses a knob of some other sort?
930LDR 03-04-2007 04:29 PM
Be careful... could be brake bias
h20cooled7 03-04-2007 05:26 PM
does it sound stock? vent control of some sort? i can see plumbing off my wastegate going to the front.
flatspin911 03-04-2007 11:15 PM
I have a Boost Knob kit for sale on Ebay if you want to see what pictures look like of this type of unit. Its quite significant and has the hoses runnig from the wastegate to it and back.
See: 260092579249
Craig 930 RS 03-05-2007 09:40 AM
Pete -
Let's see some knob head-on, and under dash pictures in order to help you -
h20cooled7 03-05-2007 11:32 AM
pic
OK ILL POST TONITE[IMG]C:\Documents and Settings\PETER LONSIAK\My Documents\My Pictures\Picture[/IMG]
h20cooled7 03-06-2007 05:46 PM
i posted the pic self titled
930turbo 03-06-2007 06:26 PM
Yup, that's a boost knob. I can see the regulator body behind the carpet.
Craig 930 RS 03-06-2007 06:36 PM
Why would someone add a boost knob to a CIS turbo motor.....
h20cooled7 03-07-2007 10:01 AM
SO THIS WILL DO NOTHING ON A CIS MOTOR?
R Wilco 03-07-2007 10:59 AM
Yea it will. I would suggest you make your adjustments in 4th gear. In every other gear things are happening way to fast.
Craig 930 RS 03-07-2007 11:15 AM
Hell yes, it will.
I assume you have EFI and he computer is adjusting the AFR when you goof with the knob.
No, you have CIS and when you "crank the knob" you are seriously messing with the AFR. This isn't an Eagle Talon, Evo, WRX, or a car with a computer.
Get above .8 bar without verification of all functioning CIS components, and you are in unknown territory.
Check, verify, and keep the boost at one level.
I guess I don't understand the obsession with "adjustable boost" - on a stock CIS 930, it is damn foolish.
h20cooled7 03-07-2007 03:27 PM
no the car is not stock i think it is a stage one ********. i think i just wnat to set for maximum boost ,can i just shut it off and leave it?
Craig 930 RS 03-07-2007 03:34 PM
We need to see some pictures and specifications - take some and dig up the info you have.
h20cooled7 03-07-2007 06:07 PM
i dont have any info thats why im asking . I bought the the car sight unseen off the net. pretty scary huh but it all went in my favor. the guy who sold it to me didnt tell me all the goodies that i got with it. i adjusted the valves and the valvetrain looked great inside. if i want full boost do i turn it clockwise or counterclockwise? i just want to put it on full boost and leave it there.
Craig 930 RS 03-07-2007 07:19 PM
Dial it up all the way and tell us what happens. Nah, don't.
Take any pictures yet?
Let's see the intercooler, boost knob, turbo, top end and the car itself.
h20cooled7 03-08-2007 03:30 AM
ill try to get them this weekend, how do you repost pics on this thread? or is it easier to just post a new one?
R Wilco 03-08-2007 09:49 AM
Get on a highway with no traffic. Preferably straight for several miles. Get it in 4th gear with the pedal floored so you are showing full boost. Then adjust it accordingly.
onboost 03-08-2007 10:07 AM
Sounds like fun!!
RarlyL8 03-08-2007 10:45 AM
Because you have just purchased this car and do not know much about how it was (or was not) built it would be wise to turn your boost controller off.
Explore your modifications and get some A/F ratio data and then start bumping up the boost as your system allows.
You can melt a piston fast if your engine is not set up to handle the additional boost.
Craig 930 RS 03-08-2007 10:49 AM
Makes you wonder what kind of treatment the car received prior to this purchase.
DDDD 03-08-2007 11:05 AM
You are in serious danger of destroying your engine if you have messed with the boost already. You should not turn the knob ANY further than what it was set at, and even then you don't know if the prior owner was a nutcase or if he cranked the boost to sell the car, or what.
You need to actually have a read out of the Air to Fuel ratio your CIS is running to know if you can safely run ANY level of boost. You can adjust all this, of course, to a degree, but basically when on boost your AFR should never get above 12.3 at the most lean spot in your rev range, and it should stay around 12.0 if possible.
Unless you are ready to do this all yourself, turn the knob down and go to a mechanic.
Do not go out on the highway in 4th gear and start driving around randomly tuning it.
Don't do anything but check the AFR and tune it correctly for a given boost level, and don't try it yourself if you are not experienced in this matter.
You need a Porsche specialist mechanic that you can trust to drive your car and tune it with a real AFR meter and maybe a dyno.
My boost knob will turn up to 2.2 bars. That would burn up my engine in minutes. You have no idea how quickly you are going to ruin your engine if you just start turning that knob.
They call it the knob of death for a reason. And most mechanics will stick it under the seat or somewhere else so a guy won't mess with it.
Craig 930 RS 03-08-2007 11:38 AM
Definitely.
Adjustable boost appeals to the "I can adjust my car and do upgrades" side of the brain - aside from that, and the fact that it can make initial & final adjustments to incremental boost increases easier - it is an idiotic device.
Think about it: WHY would you want one?
Something else: Your CIS system goes full rich at a relatively low boost pressure.
When there is enough air volume to lift the CIS metering plate fully upwards, you *have then achieved maximum fueling*
That is it baby.....there ain't no more.
Jim2 03-08-2007 11:46 AM
H2O, the ability to adjust boost upwards for more power is enticing, however there are severe detriments in doing so as Craig is suggesting above. Unless a person is technically literate with the specific upgrades done to their car (and presuming that these are the correct upgrades necessary to make the engine live) boost should not be increased. The 930 engine was designed for .8 bar boost and there is very little latitude to increase the boost before going beyond the threshold of stock CIS and pump gas.
The nuts n bolts of the problems are: air/fuel ratio correction to avoid a lean mixture as seen with stock CIS above .8 bar boost, ensuring ignition timing is correct, fuel octane adequate to avoid detonation.
The boost regulator indicates that your car has been run at elevated boost so perhaps it has sufficient upgrades, or not.
My opinion is you should spend a little time to investigate your upgrades prior to going foot to the floor. Heck, bone stock 930s should have timing and AFRs inspected. You never know what has taken place with previous owners, my own 930 being a perfect example.
Good to hear you are pleased with your car. As Craig said, try to include some pictures of the car itself. We never see enough!
Jim
79 930
Jim2 03-08-2007 11:50 AM
Geeze, a guy types up a reply and comes back sounding like an echo!
R Wilco 03-08-2007 11:55 AM
If I had my car for one month I wouldn't think I am an expert already. You damn sure can go out on a highway and in 4th gear peg it to see what your boost is. I've had a 911 Turbo for 22 years, I think I know what you can and can't do.
Craig 930 RS 03-08-2007 11:56 AM
Right on Jim and 4D - and, lacking a description of the possible modifications, a picutre or five may help us help you, H2.
These are very, very expensive to fix when they go KABLAMMO in the course of but 5 seconds...
h20cooled7 03-08-2007 01:16 PM
Okay i will tke pics this weekend and set it to 12 psi . Man getting my _ss kicked on this 1. I thought stock motors could handle 1 bar? I,ll bump the pics i psoted awhile back.
DDDD 03-08-2007 06:50 PM
A qualified mechanic will tell you what you can set it to by reading your AFR. You could be set up to run 1.2 bar, on the other hand you could be set up to run .8 bar. Who knows, until you check?
There are ways for a mechanic to increase your boost with more fuel through the CIS and also additional fuel enrichment, and so on, and your car might even have that, but you need to find out.
h20cooled7 03-08-2007 07:17 PM
how can i tell if i have the larger fuel head?
RarlyL8 03-08-2007 07:36 PM
A bone stock 930 can handle 1.0bar IF the intercooler has been changed out to an oversized unit AND the octane of the fuel is sufficient. You also need a reliable boost gauge. The stock unit is not that accurate.
The deal is that you say that you don't know what you have so it is prudent to leave it at stock boost until you do know what you have. That's all.
You don't need a modified or Euro fuel head to run 1.0bar of boost on a stock or slightly modified engine with a stock C/R. You need proper A/F ratios. (A euro head is black while a US head is silver in color). The stock fuel head will support 400HP so you have some room there.
Craig 930 RS 03-09-2007 08:59 AM
Even at 1.0 bar with a big IC and appropriate octane - bad things can and do happen.
To get that proper AFR at 1.0 bar usually requires more fueling in some areas ie more accurate and approriate fueling - and, as Brian says, it's all a guess unil you measure your AFR -- AND definitely do make a 100% system check- consisting of timing, distributor function, and the aforementioned appropriate fueling.
Yes, many times you will not need a different fuel head.
The adj. WUR......man...I'm telling ya, it really makes a difference.
h20cooled7 03-09-2007 05:59 PM
adjusted boost control but makes no difference.
h20cooled7 03-10-2007 04:09 PM
yes it does make a difference , if i cut it off it will limit it to one bar. im just gonna leave off, the car is a handfull to drive with it cranked.
NathanUK 03-11-2007 03:46 AM
IIRC the modded heads have something removed from them. Something to do with emmissions ? Hopefully someone who knows will comment.
Craig 930 RS 03-11-2007 08:55 AM
I doubt that you do have the IA fuel head - the mods on your car look to be older, and the fuel head hasn't been around that long.
IA head has something to do with the metering slit opening width -
DDDD 03-11-2007 12:38 PM
You probably experienced more wheelspin, and maybe your car also squatted on acceleration even more than usual, as well as dramatic forward weight changes when you came off the boost by backing off the throttle. Just a guess.
You can always tune some of that boost back in, but you need to set the boost at one level and tune the AFR with an AFR meter around that specific level of boost, and after that don't touch the dial of death.
If your car is handling different under more boost and you don't like it, you then have to consider bigger rear torsion bars, and revalving your rear shocks to match, or upgrading them. Unless you don't mind all the back and forth weight transfer. It sure increases the sensation of acceleration!
h20cooled7 03-11-2007 05:59 PM
the car is set up pretty tight. is there a procedure for centering the drivetrain when you install the engine?
