Ruff1's Avatar
loss of power under boost!!!!!
hi i have an 89 3.3l turbo and i started it up today after the winter sleep. i fully charged the battery and started her up and after warming up for about 10 mins i went for a drive. i went to punch it and i had a loss of power at about 3500 rpm. almost a hesitation or bucking and if i kept the pedal stable it pick up again at 4200 rpm and on. i was in 3rd it started bucking at 3500rpm shifted to 4rth it ran fine and then bucked again at 3500 to 4000 and the took of after 4000 with no problem could it be the WUR i check all the hoses they seemed fine. please help before i go get rocked by the local mechanic!
Old 04-06-2007, 10:41 PM
9dreizig's Avatar
Send a message via AIM to 9dreizig
I"ve got the same problem. Seems to be one of a couple of things.. a) over boost switch is kicking in too early or b) problem with the waste gate not opening and holding causing over boost,, hence the ob switch kicking in.. ..
As soon as my car gets here from the east coast I'm going to diagnose it
"Todd"
98 Tahoe ,2007 Saturn Vue
86 930 black and stock, 80 930 blue tracdog
91 Spec Miata (yeah I race a chick car)
"life"ll kill ya" Warren Zevon
Old 04-06-2007, 10:47 PM
Ruff1's Avatar
please let me know when u find out something. is it as easy as replaceing the switch and where is the switch and how do u tast the waste gate should i go to an aftermarket bov?
Old 04-07-2007, 09:18 AM
9dreizig's Avatar
will do !
"Todd"
Old 04-07-2007, 09:22 AM
Guys,
When gasoline sits it loses octane (even breaks down or gels if not treated at all) I suggest running the old gas out or mixing it with high octane so you don't experience detonation. This could be the cause or your rough running.
82 930 Pearl White 3.3 964 cams, K27 HF, Kokeln, fuel enriched, IA fuel head mod, wur mod, crankfire, 2X plug, Aase worked heads. 1bar, GHL, zork, 23/33 bars, low, loud
Old 04-08-2007, 04:23 PM
9dreizig's Avatar
not my problem here, the boys bringing it west probably have 10 tanks of 93 throught it
"Todd"
Old 04-08-2007, 04:35 PM
930, you may simply have a bad switch, disconnect it, be careful when you run the car up. The cars will see serious bucking and undulating if the fuel isn't flowing as well (kinked line, old pumps etc.) Ruffs car might have a fuel issue considering it was just pulled from storage.
Old 04-08-2007, 04:47 PM
9dreizig's Avatar
I agree,, but how will I know that it's a bad switch and not a bad waste gate and it truly is overboosting ??
"Todd"
Old 04-08-2007, 04:55 PM
Disconnect the wg boost line and run .8 bar (11-12 lb for a stock spring) compressed air throgh the line, if it's working you can hear the wg open up. If not you may have found your problem.
Old 04-08-2007, 05:04 PM
My apologies. I should ask, what spring/WG are you running? Headers? Turbo?
Old 04-08-2007, 05:09 PM
9dreizig's Avatar
KT27-7200 , Euro engine, 964 cams, 0,8 bar spring ...
I believe my buddy did check the waste gate as you suggested.. guess that points to the switch huh ??
"Todd"
Old 04-08-2007, 08:38 PM
If you're boost is at .8 +/- and the switch is faulty grounding the switch should alleviate the problem or at least tell you to look elsewhere. Lot of guys keep them disconnected, I personally leave mine in place even with a 1 bar tial, GHL headers and a hi flow. (switch=inexpensive, melted piston=expensive)
Old 04-08-2007, 08:53 PM
Ruff1's Avatar
does anyone know were the switch is? or have any pics on it?
Old 04-20-2007, 04:45 PM
Part #13 on this diagram: http://www.pelicanparts.com/PartsLookup/HTML/911_USA_87_89_KATALOG/107-30-Frame3.htm
'77 S with '78 930 power and a few other things.
Old 04-21-2007, 01:35 AM
Three things I have run into that are create somewhat similar symptoms.
1. Boost leak at the throttle body... one of my intercooler bolts loosened up and allowed the neck of the IC to almost seperate from the TB.
2. Overly rich situation on initial startup / warm up.
3. Bad plugs essentially allowing the engine to flood under boost/enrichment.
Rob Montgomery
'88 Blk/Blk 930 ('Lucy') - Not Stock & Not Running
Old 04-23-2007, 12:21 PM
Ruff1's Avatar
what part is this pic of? were on the motor?
Old 04-25-2007, 11:06 PM
It's the picture of the boost pressure switch you asked for.
This thread has a discussion and pictures of the boost pressure sensor (drives the gauge) and boost pressure switch (overboost protection):
http://forums.pelicanparts.com/showthread.php?threadid=337905
From your description of the symptoms, it doesn't sound like the boost switch - because if it were killing the motor at 3500-4000, it would surely be in the loop over 4200, where you say it runs OK again.
For the same reason, fuel starvation from a bad pump or kinked/blocked line seems unlikely to me - as I can't see how that would improve at higher RPM.
Old 04-26-2007, 02:08 AM
