930s rule the wasteland
h20cooled7's Avatar
Send a message via AIM to h20cooled7
rear fog light mounting info
any1 have info on this , 80 930 w/twin tip exhaust ,can i get away with this .
1980 930 Turbo
1993 Corrado
1983 944
1984 944
2001 VW golf TDI
Old 04-30-2007, 04:42 PM
Nape75'911T's Avatar
Mine is an 83 ROW car.....
and had one as OE........if that helps......
Just 3 holes in the lower valance, 2 for mounting the fog light, and one for the wires.
Switches and things are another issue you will need to address.
The factory foglight switch pulls out to turn on the front fogs, and then rotates to the right to turn on the rear. That would be a bigger undertaking......unless you are just going to wire a simple on / off switch for it......
OK, I have this car, now things are out of control !!!!
83 930 Turbo....the car I have always wanted!!
K27 7200, Tial 46mm WG with straight pipe, Fabspeed Exhaust,B&B halfbay IC, Wevo mounts, Rennline floorboards, Rennline goodies, Optima mount, Elephant finned oil lines, widemouth cooler, high speed fan.
Old 05-01-2007, 10:38 AM
h20cooled7's Avatar
very nice ! thanks for the reply
pete
1980 930 Turbo
1993 Corrado
1983 944
1984 944
2001 VW golf TDI
Old 05-01-2007, 04:07 PM
