Signal line fitting ?
I need to relocate my signal line from the WG. I am thinking about getting a -6 AN bulkhead fitting and mount it right before the AFM on the elbow coming from the IC to the AFM. My question is....would the part of the fitting that would penetrate inside the pipe cause any strange air flow restrictions or any other problems for that matter?
The signal line for the BOV has to be on the bottom side of the throttle plate(closest to the intake valve)
Roger that Ben...that is where its located. Same place Jerry showed in his pics of his install. I need to relocate my signal line for the WG. Right now it goes from WG to turbo outlet. I need to move it closer to the butterfly.
opps yeah then no problem
| All times are GMT -8. The time now is 06:08 PM. |
