onboost's Avatar
Silicone Hoses
Hey guys..
Replacing some hoses on my car.. couplers to turbo , turbo to IC, misc vaccum lines..
Any preferred silcone over another? Samco vs. TurboHose?
Thanks,
RGruppe #180
Old 05-22-2007, 01:30 PM
David's Avatar
If I'm not mistaken, Sport Hose and Samco are the same. I bought all my stuff at www.sporthoses.com and it seems to be good stuff. The original blue hoses are a little thicker walled than the colored ones.
Old 05-22-2007, 01:58 PM
onboost's Avatar
You are correct.. I meant Turbo Hose..
Did you go with the blues stuff and is it straight silicone?
I know some other hoses are fiberglass reinforced silicone.
RGruppe #180
Old 05-22-2007, 02:10 PM
David's Avatar
The hose I got have some sort of reinforcement. I tried to use black for everything but a few pieces were out of stock, so I got blue. Then I realized the difference in wall thickness.
Old 05-22-2007, 02:53 PM
onboost's Avatar
Guess its time to order-up!
RGruppe #180
Old 05-25-2007, 01:38 PM
930gt-40r's Avatar
I run all vibrant performance on mines
Kris @ Tech9
86' 930/GT-40R Sold
94' Rustang GT daily (long gone)
2008 C6/Z51 Corvette
Old 05-25-2007, 02:02 PM
WydRyd's Avatar
Any 4 or 5 ply will do... they handle a LOT of pressure. Much much more than you intend to run, so don't stress too much about which is better.
Merv
'89 911 Turbo Cab
Protomotive MAP ECU, Twin Plugged Heads, GT2-EVO CAMs, 3.3L fully finned P&C's, ARP fasteners, C2T head gaskets, Titanium Retainers, Turbo spec valves, springs & guides, 964 splash valves, GT35R BB turbo, GSF Stainless Headers, Magnaflow Exhaust, Full bay Intercooler, TiAL 46mm w/gate, TiAL 50mm BOV, Apexi AVC-R EBC, SPEC Stage3+ Clutch kit, Crane CDI Ignition
Old 05-25-2007, 05:37 PM
onboost's Avatar
That's cool..
Figured 4 or 5 ply would do the job pressure wise... just wnated to make sure I had something that would withstand the heat over several thousand miles better that the standard factory style stuff..
RGruppe #180
Old 05-25-2007, 07:00 PM
930gt-40r's Avatar
Porsche makes a nasty one for the 91-94 turbo out of silicon and it runs from turbo to intercooler. If the turbo and inter cooler that you are running are oem style, I defenatly recomend the stock porsche unit. They are expensive, but so easy to make use and they dont blow off
Kris @ Tech9
86' 930/GT-40R Sold
Old 05-26-2007, 05:47 AM
