Grinding when under load on RH Turns...
This past weekend at the track I was experiencing a grinding/vibration in RH corners, especially in RH corners with alot of load on the LR.
I didn't hear anything (of course my car is freaking LOUD), it was more that I could feel it grinding, and I could sort of feel the resistance. It would get worse as a session progressed, or once things got warmed up.
I'm guessing it's the LR wheel bearing.
We rebuilt the left side (drivers) axle at the track with new CV joints/boots, grease, etc. but it made no difference.
Any other thoughts? Could it be the diff? I can't imagine the DIFF would cause a grinding feel in RH corners??? or could it???
Any thoughts???
FYI - in the pits, weaving back and forth, if its doing it at all, you can barely notice it. I didn't really notice it in the pits or going down the street at say 25mph weaving back/forth...
Brian
Brian Keith Smith
Old 05-30-2007, 08:20 AM
It probably is the wheel bearing but also check to make sure the tyre isn't rubbing on something.
1981 930 headers, K27, 1 bar spring
1988 951S work in progress
Old 05-30-2007, 11:34 PM
Got Boost?
toally diff. car but similar situation
in a bmw 318ti I thought I had a wheel bearing going south at the track
turned out to be popped motor mounts
$.02
john
john bradshaw
comscc.com
porsche 930rs
SPA #227
Old 05-31-2007, 09:14 AM
thanks guys...
Brian Keith Smith
Old 05-31-2007, 09:31 AM
