Gumba11's Avatar
Cool EFI fuel system.....
Hey guys,
What are your thoughts on using factory fuel pumps with my EFI conversion. Can it be done? Do the OEM pump have horsepower limitations like the CIS system does?
I am trying to figure out budget wise if I can wait a litte bit before I go to the Aeromotive A1000 pump.
Thanks..................................Chris
77 930 "P Zilla" 3.2 Litre w / EFI conversion
Old 06-03-2007, 08:36 PM
Navin Johnson
TimT's Avatar
Yes you can use the factory fuel pumps. Depending on how much HP you want to extract from your engine they will work fine
'69 911 GT-5
'75 914 GT-3
and others
Old 06-03-2007, 08:58 PM
rotorhead's Avatar
I'm using the factory pumps on my EFI setup. EFI runs at a lower pressure than CIS and the pumps can therefore flow more fuel
2008 BMW 320i
2006 Mercedes ML320
2004 Mercedes ML270 cdi
1998 Porsche Boxter
1988 Porsche 930 Targa (sold)
Old 06-04-2007, 03:48 AM
DRV2FST's Avatar
Factory original fuel pumps on mine with 72# injectors and 505 rwhp.
Kirk
Crashed: Silver 1992 Turbo S2
Sold: '86 930 minor mods; '94 3.6 Turbo; '85 Euro 930 (3.2 Intake, Tec3r EFI, TwinPlug, Garrett Turbo, JE 8.1 Pistons, 505 rwhp)
Old 06-04-2007, 06:06 AM
David's Avatar
I used the factory pumps but I did replace 100% of the fuel lines. I used the OEM lines through the tunnel and braided stainless for everything else.
Old 06-04-2007, 09:05 AM
Jeff Alton's Avatar
David, what types of connector/adapters did you use to go from where the factory lines exit the tunnel to what I pressume is -6 braided?
Cheers
www.turn3autosport.com
Old 06-04-2007, 09:55 AM
David's Avatar
For the -6 braided lines to stock lines I bought fittings from www.batinc.net
If I remember correctly, they're 14mm/-6 fittings.
Old 06-04-2007, 11:07 AM
