935TURBO's Avatar
Question Wich head studs....?...on big hp engine....
Hi Turbo men....
As I had a problem with my 930 engine....head stud broken.... ....I wonder wich new ones using on my twin turbo upgrade 3.5 engine...?....does someone have experienced specially strong head studs..?....thanks.
Serge
Serge, Gentleman Driver
https://www.facebook.com/photo.php?fbid=10207116408000968&set=gm.1723624077 855805&type=3&theater
Old 05-24-2007, 03:27 PM
Porsche Junky
mede8er's Avatar
Call or email Henry....he's the man....
Henry Schmidt
SUPERTEC PERFORMANCE
Ph: 760-728-3062
Email: supertec1@earthlink.net
1986 930 RUF equipped
Old 05-24-2007, 04:10 PM
Banned
Neil Harvey/Porsche Developments, excellent studs.
Old 05-24-2007, 04:42 PM
iamchappy's Avatar
I put the Supertec studs in mine and will have no worries.
914 6 Turbo twinplug 3.12
87 924S
Lexus SC400
Lexus LS400
Old 05-24-2007, 05:09 PM
Banned
Yes, I hear they are very good too! Candy.
Old 05-24-2007, 05:15 PM
Crotchety Old Bastard
RarlyL8's Avatar
I used ARP head studs and rod bolts in my build. They have been in place for over 5 years with no issues, and I'm not easy on it.
Old 05-24-2007, 06:31 PM
WydRyd's Avatar
+1
Merv
'89 911 Turbo Cab
Protomotive MAP ECU, Twin Plugged Heads, GT2-EVO CAMs, 3.3L fully finned P&C's, ARP fasteners, C2T head gaskets, Titanium Retainers, Turbo spec valves, springs & guides, 964 splash valves, GT35R BB turbo, GSF Stainless Headers, Magnaflow Exhaust, Full bay Intercooler, TiAL 46mm w/gate, TiAL 50mm BOV, Apexi AVC-R EBC, SPEC Stage3+ Clutch kit, Crane CDI Ignition
Old 05-24-2007, 08:57 PM
930gt-40r's Avatar
+2
Kris @ Tech9
86' 930/GT-40R Sold
94' Rustang GT daily (long gone)
2008 C6/Z51 Corvette
Old 05-24-2007, 09:19 PM
David's Avatar
Old 05-25-2007, 05:08 AM
resident samsquamch
sand_man's Avatar
+4 on the ARP. However, being that he handled all of my machine work, I would have bought the Performance Developments (Neil Harvey) headstuds if I had it to do over...just to give him the business, and, well, because Neil's the real deal! I already had my ARP hardware before I found Neil.
-jeff
Old 05-25-2007, 06:07 AM
kellcats521's Avatar
It's hard to fathom that there is actually a discussion/debate on whether to use ARP or not. +5 with rod bolts and head studs.....
Old 05-25-2007, 06:30 AM
Constitutional Liberal
Turbo_pro's Avatar
Of course there is a debate.
The Supertec head studs were designed with a far superior concept.
They (Supertec) studs are made from a material some stud engineers believe is a superior choice to that of ARP studs. The Supertec stud also used a design that incorporates two different thread pitches. The case end is standard 10X1.5 thread and is slightly longer than stock. This lets you thread the stud completely into the case. More threads equal more strength.
The nut end is a fine thread 10x1.25. This allows for a more accurate torque and better control of head tension.
All high quality machinery that has a stud installed in aluminum has a fine thread nut installed. Even the Supertec nut has a better design.
If you search this board you are going to fine many comments about AR studs coming loose after very little use.
ARP studs are cheaper, perhaps there's a reason.
Debate? I think so, that's why I chose Supertec head studs for my 400 hp turbo engine.
Jim
“Rhetoric is no substitute for reality.”
― Thomas Sowell
Old 06-27-2007, 06:48 AM
935TURBO's Avatar
Thanks for your answers....interesting....
So, what about those ones, compared to the ARP....are they better and is the quality/price ratio correct......?
http://cgi.ebay.com/ebaymotors/Porsche-911-Engine-Cylinder-Head-Studs-Dilavar_W0QQcmdZViewItemQQcategoryZ33617QQihZ010QQ itemZ200123349701QQrdZ1QQsspagenameZWDVW
Old 06-27-2007, 07:37 AM
resident samsquamch
sand_man's Avatar
This was a good discussion/debate:
http://forums.pelicanparts.com/showthread.php?threadid=294898
-jeff
Old 06-27-2007, 08:06 AM
iamchappy's Avatar
I put the Supertec Studs in my engine. Debate away apples and oranges,
I cant see any negatives against using them.
87 924S
Lexus SC400
Lexus LS400
Old 06-27-2007, 09:31 AM
930gt-40r's Avatar
Ive used Arp's in everything I have built since the age of 12 and I have never had a problem. Nor have I had a problem with the Supertecs or even the Porsche motor sports/ stock studs. At the point of splitting hairs, these pieces of hardware are only as good as the builder that installs them. I think the extra cost in the Supertecs are not in the material, but the R&D. The Supertec most likely have a better expansion characteristic than the Arps because the ARPs are basically just a very high quality grade 8 bolt/stud. I use the ARPs because it is worth the 3-400$ difference to me to take the chance. If my heads lift, I buy Supertec studs- spend a night in the garage + a case of beer and away I go, my woman will wait for me...
Kris @ Tech9
86' 930/GT-40R Sold
Old 06-27-2007, 04:24 PM
