wcc wcc is offline
wcc's Avatar
O2 sensor question
Right now I left my O2 sensor unhooked and used a Gunson gas tester to set the CO%. No problem and it runs fine. But I was just thinking about hooking up the O2 again. If I do I would like to replace it with a new one. So I was wondering if any of these O2 sensors are compatible from this thread? Or are these only for the motronic system?
http://forums.pelicanparts.com/showthread.php?threadid=307164&perpage=20&highlight=ford%20o&pagenumber=2
Bill
997.2
Old 06-24-2007, 06:50 PM
I would like to test my CO. I can get the CO reader on ebay for $200. If you don't mine could you walk me through the process of checking and setting? Thanks
16 VW Touareg
05 Porsche Cayenne S
87 Porsche 930
84 VW Rabbit GTI
Old 06-24-2007, 07:30 PM
wcc wcc is offline
wcc's Avatar
I could but it may be better just to read the Gunson Manual. It's an easy read and very straight forward.
http://www.gunson.co.uk/item.aspx?cat=0&item=1835
Here's another thread as to setting the CO% that's worth looking at.
http://forums.pelicanparts.com/showthread.php?threadid=339788&highlight=Gunson
Bill
997.2
Old 06-25-2007, 04:17 AM
Bill, thanks for the info.
16 VW Touareg
87 Porsche 930
84 VW Rabbit GTI
Old 06-25-2007, 02:46 PM
A fellow Pelacanite
NathanUK's Avatar
Bman, get a wideband AFR fir inside the car. www.imagineauto.com can fix you up with an innovate XD-16 or similair. Check out http://www.innovatemotorsports.com/products.php
You can then monitor your CO throughout the whole rpm & load of the engine rather than just at tick over.
1981 UK 930. G50/01 shortened, 964 3.8RS Fibreglass Body Kit, 18" Alloys 8.5" F & 10" R, 225's F & 285's R, Special Colour Metallic Blue Paint, FIA Sparco Evo's, A/C and Air Pump removed, Electronic Boost Controller, GHL Headers, Tial46 WG.
Fitting - New service kit.
Needs Fitting - Innovate XD-16 Kit, Kokeln IC. Stephen's K27 HFS, EVO Intake Assy & his Modded USA Fuel Head.
1983 UK 911 3.2 Carrera Sport Coupe. Black, Black Leather with Red Piping, Black Alloy Gear Knob, K&N Air Filter Element, Turbo Tie rods.
Needs Fitting - K&N CO Sensor, Round A/F Dial Gauge, Factory Short Shift Kit.
http://www.danasoft.com/sig/Iamnotanumber.jpg
Old 06-26-2007, 12:22 PM
