Me like track days
http://forums.pelicanparts.com/showthread.php?p=3014126#post3014126
Update: Had the bearings/races replaced up front about a month ago while in for rotor/hat replacement. Returned from shop, MAJOR shudder up front, both sides. Never a problem before. Return to shop. Re-do of install and drive away.........shudder virtually the same. Installer says he tried all possibilities and (if I recall correctly what he said) that each side is .005-.010 runout. Also turns out he hasn't done this project often. Go to shop #2. Front (and now rear) bearings and races now replaced approx 2 weeks ago. Those same 2 week old fronts were now worn to the point where they looked ~years~ old. Shop freezes/heats to get best fit, etc. Drive away and shudder is virtually gone, barely detectable. Seems a non-issue, so I do a track day. Shudder is like a cheap hotel massage.....not good. At this point I've spent over $1,000 on the bearings/races. What do I do now? Hubs thrashed or ? Anyone else been down this frustrating road?
- Craig 3.4L, SC heads, 964 cams, B&B headers, K27 HF ZC turbo, Ruf IC. WUR & RPM switch, IA fuel head, Zork, G50/50 5 speed. 438 RWHP / 413 RWTQ - "930 is the wild slut you sleep with who tries to kill you every time you "get it on" - Quote by Gabe Movie: 930 on the dyno |
