-   911 / 930 Turbo & Super Charging Forum (http://forums.pelicanparts.com/forumdisplay.php?f=222)
-   -   CDI question (http://forums.pelicanparts.com/showthread.php?t=371736)
bcoats 10-12-2007 11:48 AM
CDI question
Just wondering if a faulty CDI could cause a car to run rich, foul plugs and/or cause some jerking when starting out in first gear? Having some issues, just replaced plugs, wires and ignition coil, new o-ring on intake manifold, running better but still have some jerking and heavy gas smell? Also, gas analyzer didn't detect any gas leaks, at a loss??? Any help greatly appreciated as always. . .
NathanUK 10-13-2007 03:50 AM
what was your CO or AFR at idle?
DDDD 10-13-2007 07:28 AM
I had a similiar problem and it turns out that my oil filler spout was missing the rubber seal around the oil cap and this was actually causing a vacuum leak that made my car hesitate at low rpms. Right where you pour the oil in the engine, the cap you remove should have a rubber seal on it or else air leaks thru and gets into your intake manifold thru the oil recirculating hose.
Sounds silly, I know, but my mechanic told me that nobody believes that can be a problem until it happens to them. Fixed my issue.
Probably not the probelm you are having, but worth checking whenever you feel a hesitation.
Anyway, the real problem you are having sounds more like your Air to fuel ratio is too rich in your CIS. You will feel 'surging' when under part throttle when it is too rich, as in your car will not stay at a steady speed and will want to lunge forward more than you expect when you are just trying to drive at a steady speed.
Your CD has nothing at all to do with your car running rich. If it was your CD, your car would be stalling out or misfiring pretty badly, I would think.
Just so you know, if you lean your CIS out too much then that will end up causing a 'bucking' feeling, sort of a hesitation. So when tuning CIS, you need to get it right in the middle between too rich and too lean.
bcoats 10-13-2007 04:43 PM
Thanks guys, CO at idle is 3%, after a couple days of driving problem for whatever reason not doing it that much, but do need to give more gas however to get rolling than I did before???
NathanUK 10-13-2007 05:03 PM
If you are sure you don't have any air leaks then you will have to get an AFR gauge like the Innovate XD-16 or LM-1. You can then see what happens while you drive.
DDDD 10-14-2007 07:53 AM
If something is not leaking air into your intake like we have mentioned, and your car is tuned right, then you would think that it is a clogged fuel filter or anything keeping gas from getting to the manifold if you need MORE gas to get it going. That is the opposite of being too rich, of course.
Some of those CIS style valve cleaner treatments will clean out your CIS system of carbon deposits. The Sauber valve cleaning bottle is good.
Keep in mind that these cars don't drive right until they are warmed up when it is cold out. My car takes ten minutes before I can get on the gas when the temperature is below about 60. It feels really sluggish before getting warmed up, hesitant. The problem goes away when the car is 180 degrees.
