-   911 / 930 Turbo & Super Charging Forum (http://forums.pelicanparts.com/forumdisplay.php?f=222)
-   -   surging at idle (http://forums.pelicanparts.com/showthread.php?t=378079)
9dreizig 11-18-2007 03:58 PM
surging at idle
My 86 stock turbo is surging at idle it will oscilliate between 600-900 rpm. When I give it enough throttle to get it to 1000 rpm it runs smooth.. Any ideas??
Other than that it runs pretty well. Well it does have a bit of a "break up problem under load when I hit the gas but this seems unrelated and is intermittant..
T
NathanUK 11-18-2007 04:37 PM
Check your IC o'rings.
9dreizig 11-18-2007 04:50 PM
ok will do , but you think that would cause the surging at idle ??
T
NathanUK 11-19-2007 11:21 AM
Yes, air will bypass the CIS measuring plate causing the car to run lean and hunt.
