how to mod k27 bracket
I am puttng on the k27 and trying to retain stock bracket and use stock euro headers. i have slotted the lower mounting holes as seen on here in other posts, but was wondering if the top one gets redrilled usually?? Anyone else have pictures of modified brackets?
Old 11-19-2007, 06:51 PM
Mine was cut and welded back to gether to fit.
don't have a picture of it.
Old 11-19-2007, 07:01 PM
I am not much of a welder so I used the bracket off a 1989 Turbo SE, part # 930 123 921 05 and everything bolted up fine. The Turbo SE used a K27 so the bracket is different than the standard 3DLZ bracket.
Old 11-19-2007, 08:02 PM
resident samsquamch
sand_man's Avatar
With my slotted bracket, I only run the lower two bolts, I never bother with that upper left hand one...
YMMV
-jeff
Old 11-19-2007, 08:06 PM
thanks guys I think I got her figured out now.
Old 11-19-2007, 08:34 PM
A fellow Pelacanite
NathanUK's Avatar
It helps to fit the studs to the turbo last when fitting the bracket. Also I had to cut the spacer off that top left hand hole. I did fit the spacer back though of course but it made the bracket easier to fit.
1981 UK 930. G50/01 shortened, 964 3.8RS Fibreglass Body Kit, 18" Alloys 8.5" F & 10" R, 225's F & 285's R, Special Colour Metallic Blue Paint, FIA Sparco Evo's, A/C and Air Pump removed, Electronic Boost Controller, GHL Headers, Tial46 WG.
Fitting - New service kit.
Needs Fitting - Innovate XD-16 Kit, Kokeln IC. Stephen's K27 HFS, EVO Intake Assy & his Modded USA Fuel Head.
1983 UK 911 3.2 Carrera Sport Coupe. Black, Black Leather with Red Piping, Black Alloy Gear Knob, K&N Air Filter Element, Turbo Tie rods.
Needs Fitting - K&N CO Sensor, Round A/F Dial Gauge, Factory Short Shift Kit.
http://www.danasoft.com/sig/Iamnotanumber.jpg
Old 11-20-2007, 01:50 PM
wcc wcc is offline
wcc's Avatar
You should post some pics of this bracket when you get it modified correctly. That way others that are about to the mod can see. Me, for example. I'm planning on putting on a K27 over the winter.
Bill
997.2
Old 11-20-2007, 01:54 PM
