spence88mph's Avatar
OBX 930 Header Question
Sorry if this has been discussed but I can't seem to find it.
My question is, where the two parts of the headers meet, is there suppose to be a clamp or something? Do you use RTV to seal them? Just seems strange to not use anything there?
Thanks in advance
Spence
'89 911 M491+Turbo
'90 964 C2
'89 944 Turbo
'88 928S4
Old 01-01-2008, 06:13 PM
Yes, you should of got a clamp with them.
16 VW Touareg
05 Porsche Cayenne S
87 Porsche 930
84 VW Rabbit GTI
Old 01-01-2008, 06:46 PM
Thanks BMAN, damn....I didn't get the clamp or any hardware gaskets etc...
Please excuse my newbieness but what sort of clamp would that be called so I can buy one?
'89 911 M491+Turbo
'90 964 C2
'89 944 Turbo
'88 928S4
Old 01-01-2008, 06:52 PM
They call it T-Bolt clamp http://www.clampco.com/products/t-bolt-std.asp
16 VW Touareg
87 Porsche 930
84 VW Rabbit GTI
Old 01-01-2008, 06:57 PM
thanks a lot mate!
'89 911 M491+Turbo
'90 964 C2
'89 944 Turbo
'88 928S4
Old 01-01-2008, 07:08 PM
Me like track days
Craig 930 RS's Avatar
Clamp that join? On B&B that join is left slip for expansion/contraction -
- Craig 3.4L, SC heads, 964 cams, B&B headers, K27 HF ZC turbo, Ruf IC. WUR & RPM switch, IA fuel head, Zork, G50/50 5 speed. 438 RWHP / 413 RWTQ -
"930 is the wild slut you sleep with who tries to kill you every time you "get it on" - Quote by Gabe
Movie: 930 on the dyno
Old 01-01-2008, 07:13 PM
A fellow Pelacanite
NathanUK's Avatar
Take that clamp off. You are straining everything.
1981 UK 930. G50/01 shortened, 964 3.8RS Fibreglass Body Kit, 18" Alloys 8.5" F & 10" R, 225's F & 285's R, Special Colour Metallic Blue Paint, FIA Sparco Evo's, A/C and Air Pump removed, Electronic Boost Controller, GHL Headers, Tial46 WG.
Fitting - New service kit.
Needs Fitting - Innovate XD-16 Kit, Kokeln IC. Stephen's K27 HFS, EVO Intake Assy & his Modded USA Fuel Head.
1983 UK 911 3.2 Carrera Sport Coupe. Black, Black Leather with Red Piping, Black Alloy Gear Knob, K&N Air Filter Element, Turbo Tie rods.
Needs Fitting - K&N CO Sensor, Round A/F Dial Gauge, Factory Short Shift Kit.
http://www.danasoft.com/sig/Iamnotanumber.jpg
Old 01-02-2008, 01:45 AM
resident samsquamch
sand_man's Avatar
No clamp on mine; didn't run one with my B&Bs and don't run one with my OBXs. Never had a leak from this junction...
-jeff
Old 01-02-2008, 02:18 AM
Same on GHLs.
'77 S with '78 930 power and a few other things.
Old 01-02-2008, 02:26 AM
You can force some RTV in the groove before pushing them together and bolting it up... won't hurt anything but the RTV may dry partially ruining any sealing qualities before you finish moving it around getting the header flanges onto the studs and around the oil line next to the #3 cylinder.
that can go quickly or be a pain in the... I have to have the B&B stainless braided 90degree oil line fitting loose while fitting the headers onto the exhaust studs to manuever things around, then position and tighten it as the headers are snugged up.
That B&B header joint there is around an inch deep and a snug fit. I've never heard mine leaking so it's not a problem.
Clamping sounds like a bad idea since the headers and the engine will expand different amounts and that joint lets the two sides move or slip away and back from each other a little during heat cycles without creating stress and eventually cracking.
Clamping it will squeeze the outer pipe down a little and probably make it harder to take apart and refit in the future.
Old 01-02-2008, 10:22 AM
Porschephd's Avatar
This joint has to exapand. DO NOT CLAMP IT!!
Stephen
94 3.6Turbo 6-speed AWD
Old 01-02-2008, 11:49 AM
A fellow Pelacanite
NathanUK's Avatar
The clamps that come with headers are for the heater pipes.
Old 01-02-2008, 12:51 PM
Well looks like the clamp will be coming off in the spring
16 VW Touareg
87 Porsche 930
84 VW Rabbit GTI
Old 01-02-2008, 02:31 PM
Macht Schnell
les_garten's Avatar
Hi,
I bought these used from a Pelicanite. They don't have an expansion joint at all, they are solid. I think I have some leaks inside the heater boxes.
http://www.lesgarten.com/pix/porsche/DSCF0608.JPG
Les
---Les Garten---85 930, Andial IC, GHL Headers, Fabspeed Dual, K-27 HF2, 3.4 JE Full Finned 7.5:1 CR, 964 CAM'd, Carerra 3.2 Manifold Cut/Flipped, Tec3r, Siemans 55#, GSF Fuel Rails, Clewett Crank Trigger, Clewett Cam Trigger,Dual Plugged, ARP Head Studs/Rod Bolts, Clewett Wires.Tial 46mm WG, Tial 50mm BOV, WEVO Shifter,934 Boost Gauge, Wideband EGO Sensor/Gauge, C2T Head Gaskets, '88 MB 300TE,BMW R100RT
Old 01-02-2008, 04:42 PM
930gt-40r's Avatar
+ 1 on no clamp, the collector under the turbo will crack into a million pieces
Kris @ Tech9
86' 930/GT-40R Sold
94' Rustang GT daily (long gone)
2008 C6/Z51 Corvette
Old 01-02-2008, 04:49 PM
Porschephd's Avatar
Keep in mind that the motor under boost can and will expand up to 5mm! What will happen to the pipes if solid or clamped. Something has to give!
Stephen
Old 01-02-2008, 06:56 PM
Macht Schnell
les_garten's Avatar
Hi Stephen,
A question. Are all Headers for 930's, with the exception of mine, equipped with some type of expansion/slip joint?
Ohh, by the way, after I put the flow restrictor in the oil line, I quit smoking out the neighbors! DOH!
Les
Old 01-02-2008, 08:34 PM
Porschephd's Avatar
Only the ones that last. All the ones that I know of are slip fit or have an expansion joint in it to cope with the movement of an air cooled aluminum motor.
LOL, don't feel bad, I have shops all the time get mad at me when I tell them check to see if you put the ball in. I am always greeted with "well it worked fine with the other turbo" LOL, yea I know....check the ball.
Stephen
Old 01-03-2008, 07:51 AM
spence, im thinking about trying the obx headers but i would like your feedback re: installation and performance. what kind of turbo ic etc are you running? thanks in advance , kevin
Old 01-04-2008, 04:17 PM
Be sure to inspect them carefully inside!
We found few nearly loose grinding pieces
in them. If those go in your turbo....
Falk
87 930 bblk/blk
88 3.6 white/blk
Old 01-05-2008, 06:20 AM
