-   911 / 930 Turbo & Super Charging Forum (http://forums.pelicanparts.com/forumdisplay.php?f=222)
-   -   3.2 dyno chart (http://forums.pelicanparts.com/showthread.php?t=387476)
jbrinkley 01-15-2008 01:40 AM
3.2 turbo dyno chart
Someone in this town finally bought a dyno and Phil and I went up there yesterday
Phil picked up a 2005 gt3 which he ran first. It's flashed and has a full miltek exhaust. This car dyno'd at 372 rwhp at EVOMS on a mustang.
Today It ran almost the same numbers on this dynojet.
So I believe this/these numbers to be pretty close to a true number.
I'm not all that concerned with what it makes, I'm happy with it the way it is. It's been on there for 15 months now without any problems @ .6 bar. Todd says it's good for .7, but I'm not going there.
I don't know what to say about his AFR numbers. I trust my LM logs more than this wideband. I assume it's smoothed way out or something. I recorded two runs along with the dyno runs and got the same numbers I've been getting all year.
I have the raw files from winpep7 but can't open them yet.
For anyone that doesn't know, this is all bolt on stuff. Stock compression, @.6 bar
here's a chart and a LM1 screen shot of the same run
http://forums.pelicanparts.com/uploa...1200389866.jpg
http://forums.pelicanparts.com/uploa...1200389931.jpg
patkeefe 01-15-2008 02:48 AM
Jerry, that's a lot of power!
Pat
mb911 01-15-2008 05:13 AM
not bad.. I am impressed.. and am going up to .6 bat on mine now
raceman 01-15-2008 12:04 PM
wow. l`d love to dyno mine. Are you running the stock 3.2 throttle body? that is a big restriction there and installing a bigger one should free up another 10% or so. l have mine bored out to the max diameter possible,the difference was quite dramatic.My next mod will be a diverter in the plenum under the t/body.These diverters show big improvements on the later turbos,almost unbelievable Hp gains actually if you read the dyno sheets. l think a lot of Hp can be "liberated' buy flow inprovements,the 3.2 shows it`s weaknesses there once you put the squeeze on it..
jbrinkley 01-15-2008 12:12 PM
agree 100% I think the flow is biggest obstacle at the moment.
and yes stock throttle, and afm.
WydRyd 01-15-2008 03:46 PM
[QUOTE=jbrinkley;3705303] Todd says it's good for .7, but I'm not going there.[QUOTE]
Why not? I ran 0.7bar on mine for years before going up to Stage3. Never had any problems at 0.7bar on stock C/R :cool: Neither did Juan, Mike etc...
Anyway, nice numbers. That puts you at about 375-380 HP at the flywheel @ 0.6bar. That extra 0.1bar will take you up to near 400HP :cool:
jbrinkley 01-15-2008 03:52 PM
Cause it's scary man, lol
I might put the .7 in next time on the dyno though just to see what .1 difference does
WydRyd 01-15-2008 03:57 PM
Expect close to 20-30Hp gain with an extra 0.1bar / 1.5psi of boost!
Don't be scared... enjoy the boost! :D
930gt-40r 01-15-2008 11:10 PM
Jbrinkley, dont worry about the dyno AFR, keep your lm1 hooked up and read from that. I have seen so many dyno AFRs read all over the place.
jbrinkley 01-16-2008 01:17 AM
will do, thanks
