Send a message via MSN to MKEDF
Thumbs down 915 Tranny with 930 1977 tranny Trouble..
Im practically new to turbos, but willing to start on the dark side, i got this car a 1975 911S from a so called "wolf motorsports"...
The engine pulls strong, but the first gear on tranny died yesterday..
I checked oil for the tranny and came out with scrap...meaning tranny is about to die...
I know that 915 may not be the best or even proper one to run with a 930 engine, but this is the way the car came..
The car starts really slow and poorly on first, but as the turbo and engine start to pull 2nd, 3rd, 4th,and 5th, feel good...
I guess i must drop engine and tranny to take a look at the first gear, need assistance...any one?
MKEDF, 911 78 SC (rebuilt), 75 S Turbo,2001 330CI Coupe, 2001 325I, 2001 Merc C240 V6,2003 330 I F1 (E46), 2002 320 I F1 (E46), 1999 323 I (E46),2001 Peugeot 406 Pinifarina Coupe, 2001 325 I (E46), 2000 328 I (E46), Volvo S60, Audi A4 2009, Audi A4 2008, A4 2007,2005 Boxster S, 2002 Boxster Stick Camel, 2004 Boxster S Tip (nightmare) 2003 Boxster 2.7 Tip, 2002 Boxster 2.7 Stick, Porsche 944 1983
Old 01-20-2008, 01:46 PM
beepbeep's Avatar
Oh dear.
915 mated to 930 engine? 1:st gear tooth stripped?
Thank you for your time,
Old 01-20-2008, 02:34 PM
Oil with scrap..
Yeah it seems like 1St Gear is stripped...not shure..
Just as i checked oil, it came out with scrap metal...
1st Gear engages well, but car barely moves..
So i guess it is gone...
Any thoughts?
Old 01-21-2008, 10:50 AM
E-85 sippin drunk
turbobrat930's Avatar
use the search button... and throw that 915 away or to someone who has a N/A 911 or 914... get a 930 4 speed or g-50... dont waste your money on rebuilding your 915...unless you like rebuilding transmissions every few years... spend the money, do it right the first time,...and never look back
Brad...930 gt-1 racecar, increased displacement to 3.6L, JB racing Cylinders, JE 8 to1 pistons, stroked crank, Carrillo rods, extrudehoned 3.2L intake, full bay Bell I/C, GT-2 EVO cams, Rarly8 headers, GTX-3584RS turbo, twin plug, P&P heads, Link G4 EFi system, G-50/50 with LTD slip and oil squirters/oil cooler, zork tube, full race coilover system, with carbon fiber body, full cage, E-85 sippin drunk
Old 01-21-2008, 12:44 PM
A fellow Pelacanite
NathanUK's Avatar
You might of only ripped off the dog teeth, no biggy if you are able to change them yourself.
1981 UK 930. G50/01 shortened, 964 3.8RS Fibreglass Body Kit, 18" Alloys 8.5" F & 10" R, 225's F & 285's R, Special Colour Metallic Blue Paint, FIA Sparco Evo's, A/C and Air Pump removed, Electronic Boost Controller, GHL Headers, Tial46 WG.
Fitting - New service kit.
Needs Fitting - Innovate XD-16 Kit, Kokeln IC. Stephen's K27 HFS, EVO Intake Assy & his Modded USA Fuel Head.
1983 UK 911 3.2 Carrera Sport Coupe. Black, Black Leather with Red Piping, Black Alloy Gear Knob, K&N Air Filter Element, Turbo Tie rods.
Needs Fitting - K&N CO Sensor, Round A/F Dial Gauge, Factory Short Shift Kit.
http://www.danasoft.com/sig/Iamnotanumber.jpg
Old 01-24-2008, 09:52 AM
Me like track days
Craig 930 RS's Avatar
That a magnesium case on the 915?
- Craig 3.4L, SC heads, 964 cams, B&B headers, K27 HF ZC turbo, Ruf IC. WUR & RPM switch, IA fuel head, Zork, G50/50 5 speed. 438 RWHP / 413 RWTQ -
"930 is the wild slut you sleep with who tries to kill you every time you "get it on" - Quote by Gabe
Movie: 930 on the dyno
Old 01-24-2008, 11:38 AM
Arrow Not a mag case...
It is a 82 915 tranny, aluminum, not magnesium...
By the way happy ending, the problem was the shift coupler, i read the thread about adjusting the shift coupler,and it worked great..
Now shifting smoothly, but now i know i must be careful with 1st gear, it could go away easily if fun goes out of order...
Damn... im a turboholic!!!...
Thank you all...
Mick..
Old 01-27-2008, 09:42 AM
Sweet!
Actually, I've been told that 3rd is the weakest gear in a 915. Hayden (WEVO) says it's too much torque at low RPM that breaks 915's, IIRC. His rule-of-thumb is 350 ft/lbs and 5,000 RPM.
I've got a 915 and never stand on it in 1st, because I did that once or twice and it was just scary. It's far too low to be doing that.
Conditions permitting, I rev in N/A mode (no boost) to about 3-4000 and then get into 2nd, roll the power on until 3,000 or slightly more and then stand on it until redline.
The higher gears, you're already spinning pretty good, so just shift and stand on it again until sanity (or fear) prevails. Cars in the rear-view which aren't dots at this point are going pretty darn fast.
With a better turbo, you gain the ability to treat the throttle less like a light-switch - because it'll start to spool sooner, and you don't need to stuff in full throttle to get boost.
'77 S with '78 930 power and a few other things.
Old 01-27-2008, 01:13 PM
A fellow Pelacanite
NathanUK's Avatar
First and second syncromesh get a hard time, but that's nothing to do with torque.
Old 01-28-2008, 01:36 PM
