-   911 / 930 Turbo & Super Charging Forum (http://forums.pelicanparts.com/forumdisplay.php?f=222)
-   -   First steps on the dark side (http://forums.pelicanparts.com/showthread.php?t=398153)
Cowtown10 03-13-2008 07:41 PM
Just bolting up a new single outlet FABSPEED exhaust along with the air intake and a 1 bar spring.
Other than keeping the stock exhaust to return the car back to stock, which may or may not ever happen. Is there any market for the OEM exhaust/air intake? Value??
Thanks in advance
icemann427 03-13-2008 07:45 PM
Do you need them for your annual smog checks?
Cowtown10 03-13-2008 07:58 PM
Icemann,
Since the car is over 15yrs old it is essentially grandfathered in, which also gets around things like daytime running lights, impact bumpers etc. We have no smog tests to speak of, once a car is registered it is good to go.
Cowtown10 03-23-2008 08:18 PM
After installing the Fabspeed air cleaner, exhaust and 1 bar spring, I am noticing increased oil consumption decrease in mileage, soot around the exhaust tip and rear of the car(oil in the combustion chamber i assume). The car also smells like it is running very rich.
I am using 94 octane, no other mods to the car
Is this a air fuel mix issue? valves? Is 1 bar too much?
Any input appreciated
wcc 03-24-2008 05:47 AM
1 bar isn't too much IMO. That's what I have and haven't had any issues. I believe the cut off switch is at 1.2bar.
I wouldn't be surprised at lower mileage. Because you probably gained some HP with your mods and might be running it harder.
Yes, the first thing I would make sure of is the AFR. Get that set and try again.
RarlyL8 03-24-2008 06:15 AM
1.0bar may be too much if you are also using a stock intercooler.
More heat is added with more boost and should be offset with a more efficient intercooler.
Mileage and oil consumption should not be significantly affected if driving habbits remain the same.
A/F ratios should theorietically be more lean with higher boost and free flowing exhaust.
Cowtown10 03-24-2008 08:12 AM
Options for an IC...I am a little wary of B6 quality, fit and serivce issues.
Other choices??
I would have thought the same thing that the car would run lean if anything, but the soot on the tailpipe etc tells a different tale. Hypothetically, if the O2 sensor is out of whack does the car "default" to a rich mix?
Les suggested an LM-1 AF Ratio Meter which sounds like a must have. Or the in dash by C2.
Again thanks for all the input...great info on this forum for a rookie
(at least i fixed my clock yesterday):)
wcc 03-24-2008 09:08 AM
I have a B&B intercooler and I'm very happy with it. It's a direct bolt in replacement. Those other units include updating to a BOV etc. I like the simple drop in place.
I started out with a Gunson. Where I set it with the Gunson then checked it with the LM1 and it was right on. The big difference between the two is the LM1 will give you the AFR for all RPMs. Plus it saves the data. I recently sold the Gunson and upgraded to the LM1.
Yes or if you unplugged it it will run rich. From my understanding of these cars though is it only uses the O2 sensor at idle. Long story short, unplug the sensor and set your own AFR. This is what I did.
rsrmike 03-24-2008 11:03 AM
I'm assuming you removed the catalyst to intall the exhaust?? If so it will ALWAYS smell rich. (even if it's lean) The cat is a pain but it does wonders for exhaust smell.
Most fairly stock 930's will run rich at 1 bar if everything is working right. You will definately use more fuel as well. I would bet you already had a fair amount of oil consumption but perhaps it wasn't as noticable?
You may be driving the car harder due to the increased fun factor of more boost/noise- This will increase fuel and oil consumption.
Stock intercoolers aren't as bad as people think if you stay on public roads in an average climate. They are more than effective enough to get your @ss locked up in jail long before intake temps become a problem. Track cars are a different story...
How much oil are you using?:confused: You may want to divert your intercooler money into a top-end rebuild fund if it is excessive. The added heat/pressure of 1 bar will certainly accelerate the valve guide wear. Carbon build-up and oil mixed with the air/fuel is a nasty recipe for detonation, especially at 1 bar, even w/ a better intercooler... $.02 good luckSmileWavy
Craig 930 RS 03-24-2008 02:11 PM
1 bar with no other changes.........no good, senor.
Your AFRs need a checkup asap.
NathanUK 03-24-2008 02:25 PM
I advised this also. Stock 3LDZ, stock IC + 1bar is not ideal.
Craig 930 RS 03-24-2008 02:38 PM
"Jingle, clingl clink" hey that's the broken rings song!
Cowtown10 03-24-2008 05:03 PM
Ok now I am thinking about back down to .8 bar. Very gun shy as I do not want to gernade the engine
I am monitoring the oil and fuel consumption, the fun factor definitely plays a big part.
For my knowledge what should the upgrades be to support a 1 bar? I understand the IC but the turbo? etc.... and why
I will have the AFR dialed this week.
Thanks again
NathanUK 03-25-2008 12:39 PM
You mean these custom rings Craig ? :)
http://img102.imageshack.us/img102/7...onringstm7.jpg
NathanUK 03-25-2008 12:41 PM
Thanks again
The stock turbo will produce very hot air at 1bar compared to a K27.
I went for a K27HFS.
You may well need a Brian Leask WUR with the RPM solenoid to get the AFR as correct as possible.
