Me like track days
Big port heads
FYI, not mine:
Made a difference on my car.
- Craig 3.4L, SC heads, 964 cams, B&B headers, K27 HF ZC turbo, Ruf IC. WUR & RPM switch, IA fuel head, Zork, G50/50 5 speed. 438 RWHP / 413 RWTQ - "930 is the wild slut you sleep with who tries to kill you every time you "get it on" - Quote by Gabe Movie: 930 on the dyno |
I wouldnt mind buying those and completly going through them.... with a porting bit
Craig- are yours stock with the exception of the valves? Definatly flow a lot more than stockers.
Kris @ Tech9 86' 930/GT-40R Sold ![]() 94' Rustang GT daily (long gone) 2008 C6/Z51 Corvette |
Me like track days
Comparing the exact same build on the same dyno of 2 other 930s - my car had approx 20 more HP with the early SC heads.
930 heads are just too small of port - the old tech turbochargers *required* high velocities and thus the small port/runner sizes. ANY hi-po rebuild really should have these. and the relative cost is not that much - you'll be rebuilding the heads anyway
sudo apt-get purge 930
Are you saying you get more HP with SC heads on a 930?
Mark 1979 930 Euro ***GONE AND DON'T MISS IT AT ALL*** "Worrying about depreciation on your car and keeping mileage down is like not ****ing your girlfriend so her next boyfriend finds her more appealing" --clutch-monkey |
Me like track days
No doubt. And during a total rebuild into a hi-po 930, it is something that ought to be considered, or, actually should be done.
Mine is not a high HP car. It is a 1979 RoW 930 with just a K27-7200, will have SC cams, it currently has euro HE's, may go headers and larger IC in the future. Is there any benefit for someone like me?
Me like track days
I would add them if:
1) Complete engine rebuild 2) High HP as goal 3) K27 HF or K27 HFS turbo (not certain if a K27-7200 would suffice, I just don't know) 4) Exhaust and fuel have both been optimized to a high & accurate level And a definite must if EFI is in the future
Ok, thanks. It doesn't look like these will do much for me.
Me like track days
Pictures -
Big port SC heads ready for some port work:
![]() ~~~~~~~~~~ If you want a high HP CIS motor, these 78/79 SC heads are the ticket, and here is what they look like after some work: ![]()
Metal Guru
Craig, was your intake manifold ported to match the heads?
Paul B. '91 964 3.3 Turbo Port matched, SC cams, K27/K29 turbo, Roush Performance custom headers w/Tial MV-S dual wastegates, Rarlyl8 muffler, LWFW, GT2 clutch & PP, BL wur, factory RS shifter, RS mounts, FVD timing mod, Big Reds, H&R Coilovers, ESB spring plates- 210 lb |
Me like track days
No In my opinion, there is not enough edge margin on a 930 manifold to do this and make it worthwhile or safely functional.
What truly makes the biggest difference is the head runner/port size increase with the higher volume turbochargers of today.......believe it or not.
Well, he agreed to a buy it now of $500 so I bought them. I figured it would be nice to have a spare set AND have the option in case I go big later.
Me like track days
Nice. Combine it with:
Appropriate fuel & intercooler .9 bar GHL or B&B headers 964 cams Zork With this, there is no reason you can't get 425 RWHP on a dynojet for a 3.3 - Flame ringed heads are also a good idea
In the words of Borrat- "Very Nice!"
Craig- not only do I like your ports- but that shroud around them is just tits... What do you think- I got the 3.3 heads that have had material added to the outer perimiter of the intake port and ported to match 3.2 heads- Good or no good? would it have been smarter to just do 3.0 heads?
Me like track days
3.0 heads hands down - the 3.3 930 heads are tiny and can't be adequately modified.....
All must remember that they HAVE to be 78/79 heads for the large ports -
Well life lesson learned- next time around I go 3.0 ported heads..... Elgine cams and 906 rockers...
Hey another question- our rockers are 1:4 rocker ratio and the 906's are 1:5- could I get away with my GT-2 cams or is there too much lift for a 1:5 rocker?
Me like track days
Skip the odd stuff and go with proven components:
964 cams, 930 rockers, 3.0 heads, K27 HFS from Ultimate Motorwerks, B&B or GHL headers, fuel management, .9 bar You will have 430+ hp - AT THE WHEELS not peaky, usable, flat-ish torque curve and USABLE POWER
well im gunning for about 550 or 600 this year- the reason I ask is my buddy is running the elgins in his drag car with the 1:5 rockers. I hear what your saying with the proven setup and I know that works well for the most part- Im just trying to run with the big dogs
