-   911 / 930 Turbo & Super Charging Forum (http://forums.pelicanparts.com/forumdisplay.php?f=222)
-   -   Reversed firing order (http://forums.pelicanparts.com/showthread.php?t=401920)
h20cooled7 04-03-2008 06:19 PM
Can this be done on a boxer motor, or do 911 builders do this ? I was taking to a v8 builder and he said you can get the cams ground to reverse the firing order so it will fire from the middle to the outside cyls and it creates balance and some serious HP. Just trying to get enlightend.
les_garten 04-03-2008 08:23 PM
Hmmm, Porsche has been working on this motor for almost 50 years. You'd think they would have thought of this!
Flieger 04-03-2008 09:16 PM
I think that the conventional firing order for a flat 6 is as balanced as a street motor can be. It is balanced better than any other configuration so I do not think that a change in firing order would help much because there is no problem to eliminate.
JV911SYDNEY 04-03-2008 10:12 PM
It is common for MOTOGP engineers to play with firing order...you'll know doubt have heard of "big bang" engines.
Doesnt produce more power but rather changes the power & torque characteristics
http://www.motorcycledaily.com/08april05_bigbang.htm
les_garten 04-03-2008 10:13 PM
Straight 6, Flat 6, or in line triple are perfect engines. All are 120 degree cranks. A great read is "The Design and Tuning of Competition Engines". It is EXTREMELY hard to improve on perfection!
spuggy 04-04-2008 12:52 AM
Well.... Mostly, anyway....
Just as a point of interest, the Laverda Jota (a 1000cc triple, originally a UK-only importer-tuned special based on the Laverda 3C) used 180 degree cranks for most of the production run, although Laverda did switch to 120 degree cranks towards the end.
Sounded rather special - you could clearly hear the gap in the firing order when it was at cruising RPM, like a 4 with a cylinder missing...
les_garten 04-04-2008 06:50 AM
Heh! Drunk Italian Engineering notwithstanding...
Here's the sound the Laverda makes, I don't have the associated pic of it vibrating like a freakin washing machine!!
http://www.thecreeper.net/laverda/jota1000.wav
Les
h20cooled7 04-04-2008 07:14 AM
Cool cool ,just throwing it out there. Thanks for the a$$ kicking.
