-   911 / 930 Turbo & Super Charging Forum (http://forums.pelicanparts.com/forumdisplay.php?f=222)
-   -   I need some cylinders.... (http://forums.pelicanparts.com/showthread.php?t=402489)
polizei 04-07-2008 05:54 AM
Hey guys,
I have posted in the classified section without any luck, and I was hoping that one of you might be able to help me. I need a set of reconditioned (in spec) 3.3 or 3.4 L cylinders. I'm planning on running 8.0-8.5 compression, so the pistons aren't important unless you have a higher compression set.
Even if you have a suggestion of someone that may have a set, please let me know. Thanks guys.
toddlwitte 04-12-2008 10:04 AM
i now have a set of 3.3 cylinders. there is only 35k miles on them. reason i have them is: simple in the shop last August to get a new clutch, turned into splitting the cases, and rebuilding with: 3.4 nikkis, 8:1 Je pistons, everything coated, IS twin pplugged worked over heads, springs etc, k27hf2, tial wg, adj wur,kokeln IC, SSI headers & exhaist, electronic iginition, and a whole bunch more i dont even know but paid for. Oh there wasn't anything wrong with teh engine, it was in excellent shape. AND i did get a new clutch out of it, says so on page 4 of the bill......:p
so i do have a set of 3.3 cylinders. I am in york, PA. not sure which Lansdale it is, but i know theres one on the "bad side" of the river...LOL
oops, i guess that could start a flame war, so i'll leave it as the other side of the river.
:D
