-   911 / 930 Turbo & Super Charging Forum (http://forums.pelicanparts.com/forumdisplay.php?f=222)
-   -   More Turbo Option ????'s (http://forums.pelicanparts.com/showthread.php?t=402599)
Ronnie's.930 04-07-2008 05:23 PM
Hello all - thanks to advice given by members of this forum, I'm fairly certain that I am going to purchase a new turbo for my 1987 930 rather that get the stock 3ldz rebuilt (I am currently overhauling the engine - keeping it mostly stock save for Racewear hardware) . . . I have been in contact with Kevin of "Ultimate" with regard to options and pricing and such . . .
My question for all of you: given my goals (reliable but perhaps a little more powerful than stock . . . daily driver with occasional track-day use at Motorsport Ranch, Cresson TX - were I am a founding member) what turbo would you recommend (K27-7200)? What is the performance difference between the K27-7200 and the High Flow variety (the price of the high flow is MUCH greater)? Given the FORTUNE I am dropping on the 24K engine overhaul, the price for the 7200 seems good for me!
As I mentioned earlier, mostly stock with the exception of hardware and muffler . . .
Thanks!
Ronnie
David 04-07-2008 06:04 PM
Kevin should steer you right with what you want to do. If you're losing traction on the slippery slope to big hp (and the higher powerband that comes with it) you could get something else, but if you just want a good reliable, more modern replacement for the 3LDZ, the 7200 sounds like the way to go.
spuggy 04-08-2008 12:27 PM
As I understand it, the K27/7200 is very similar to the 3DLZ, just marginally better.
My $0.02? SC cams for a balance between off-boost response and better/more top-end (you get both), and a K27/HF. Much faster spool, way more mid-range and more top-end. More power, but no big step.
However, Kevin doesn't do the HF anymore, so it's a choice between the S and the HFS.
I figure that the S will spool faster, but not develop as much power up top, the HFS would take a little more to spool but just keep on going at the top.
With a 4-speed and primarily street driving, I'd guess that the S might be a good selection.
with a 5-speed, the HFS would be a shoo-in, I think.
JimCulp 04-08-2008 01:25 PM
Some folks are using the Garrett turbos. I don't know much about them, but they're an alternative.
David 04-08-2008 02:38 PM
There is a Garrett being made that's a bolt on but I forget who's selling it. I just don't believe they have the quality of the KKK turbos.
Craig 930 RS 04-08-2008 04:17 PM
24k so far? I'd get the K27 HFS from Kevin and you will be quite happy with it. I am -
Ronnie's.930 04-08-2008 05:33 PM
Ha, Craig . . .by 24k I meant "24 karat gold" (as in "perfect") . . . an expression that one of my friends uses to describe my "projects" (poking a little fun at my "analness" as well) !!!
Thanks for the responces thus far . . .
Ronnie
infraredcalvin 04-09-2008 09:32 PM
If you are planning on running mostly stock, go with a true bolt in application. There is no sense in having to fab anything if your performance goals are near stock.
I have a new Kokeln turbo that I'm very happy with. It was truly a bolt on application as I believe the K27/7200 is. I know some here don't like the Kokeln, but you need to know your HP goals and choose accordingly.
Ronnie's.930 04-11-2008 07:49 PM
I'm going to look into the Kokeln option - I passed on the eBay auction due to your comments on my post regarding it (Infafredcalvin) - thanks !!!
Ronnie
infraredcalvin 04-11-2008 10:51 PM
Ronnie
Where are you located? I'm in Southern California, my mechanic is the guy who started Kokeln, he's a great guy (but expensive as he$$ to have work on your car- but he does everything the same way I would - the right way), anyway he actually started to steer me towards the K27 just because it was the "name brand" that most people talk about, after we talked and I explained my ultimate hp goals he set me up with the Kokeln. It's set up real nice right now, the only thing is that you could hear the original KKK spool up, this one I haven't been able to hear - although that could be a result of my stock exhaust.
Let me know if you want more info... I'm glad you didn't get stuck with that ebay frankenstein turbo...
Ronnie's.930 04-12-2008 08:19 AM
I live in the Dallas, TX area . . . I haven't contacted Vision yet but have browsed their website . . . I am curious to hear what you paid for your kit (PM me if you like) . . . what did you tell them was your HP goal ?
Ronnie
infraredcalvin 04-12-2008 09:11 AM
PM Sent
Porschephd 04-12-2008 05:42 PM
Actually this is a little off. The 7200 or the K27S will run 1.5 seconds faster through the 2-6K RPM band over the 3LDZ and will add on average 38HP. They are not even close to being like a 3LDZ.
Chuck Jones 04-12-2008 07:41 PM
Way to go PhD....keep the facts straight.
