930 heat exchangers
I Would Like To Know If A Set Of 1988 Turbo Heat Exchangers Will Fit On A 1978 Turbo Engine. Thanks For Any Advice I Receive, Larry
Yes. 3.3 engine is virtually the same between 78' and 89'. Certain markets had O2 sensor, others didn't. But head spacing and port dimension is the same, thus it's a bolt-on.
Thank you for your time, Last edited by beepbeep; 06-25-2008 at 02:44 AM.. |
I bought a set of the older SSI heat exchangers and had to hammer out (i.e. put a dent in it)a bit of space for the "C"spring on the clutch to clear the exchanger on the driver's side. As you know, that spring expands and contracts as you activate the clutch, and prior to modifying the exchanger, it would bind up against it. Is this something that perhaps the newer versions of the SSI took into consideration? If not, then you might run into the same issue...dunno. RarelyL8 is the guy who would know....
1987 factory Slantnosed 930 Cabriolet/Guard's red 2002 Midnight Blue 996TT X50 1999 Iris Blue 996 (Dash fire burned and totalled 9/07) |
cycling has-been
it also depends on if you have the short four speed or the long one.
the short trans requires some modification to the crossover tube. you will also need a system-specific oil drip tank and connecting plumbing, regardless of the trans involved. Bill K
73 911T MFI, 76 912E, 77 Turbo Carrera |
Crotchety Old Bastard
The '88 930 heat exchangers are the typical "Euro" configuration with the J-pipe and O2 bung.
They will fit a USA '78 but require the ROW oil line that wraps around the flywheel area of the engine and the correct log shaped drip tank. I have pictures if you need to see something. My personal car is a '78 and has '86 heat exchangers which are the same as '88.
RarlyL8 Motorsports / M&K Exhaust - 911/930 Exhaust Systems, Turbos, TiAL, CIS Mods/Rebuilds '78 911SC Widebody, 930 engine, 915 Tranny, K27, SC Cams, RL8 Headers & GT3 Muffler. 350whp @ 0.75bar Brian B. (256)536-9977 Service@MKExhaust Brian@RarlyL8 |
This is a dumb question and slightly off topic. What are heat exchangers. I know they act as headers by getting rid of exhaust gases from the block and funnels it through the exhaust. But is this the mechanism used to generate heating for the car? If so, how does it work exactly.
I don't own a 930 or early 911 and have just recently started coming to this forum, although I've always loved how the 930 looked and fell in love with them when I saw one at an auction. So please forgive my ignorance.
Banned
Heat Exchangers = sheet metal that is formed around the headpipes (with airspace in between and an "in" and "out" for air) - the air is warmed by the headpipes and pumped into the cabin (when the flappers are in the "open" position) . . .
Ronnie |
