jh225's Avatar
Rear Decklid....Quick Question
Figured I would ask this here as those with a turbo would have the answer.
I have acquired a right side (passenger side) deck lid hinge supposedly from a turbo car so I can mount a second deck lid strut to my 85 911 with a whale tail.
Only problem is this.........It was sent to me so I am not sure it is correct. This hinge has a triangle shaped plate that is spot riveted to it. On my left side hinge there is sort of a raised pad that the strut goes in between just like on the firewall. On this right side one, there is just a welded nut on the one side that appears to be where the strut attaches.
Is this the right part? Anyone that can snap a quick photo of the way their strut is mounted?
The firewall mount on the car is the same on both sides so I would think the deck hinges should be too, no?
1985 Carrera Targa in the fastest color......Black........Growing list of goodies now includes SW Chip, M&K premuffler, Sport muffler, DME update, etc.
Old 07-09-2008, 05:01 PM
sudo apt-get purge 930
equality72521's Avatar
Pictures would make this much easier.
--clutch-monkey
Old 07-09-2008, 05:08 PM
jh225's Avatar
You are correct, stand by.
Old 07-09-2008, 05:16 PM
jh225's Avatar
Old 07-09-2008, 05:22 PM
Yes, that looks exactly like my passenger side hinge on my turbo.
--clutch-monkey
Old 07-09-2008, 05:26 PM
DSPTurtle's Avatar
I just popped into my garage and took this for you. If it is not the angle you need just let me know and I will shoot from a different angle. Any excuse for me to not have to work on my engine
JB - BreitWerks
www.breitwerks.com
321-806-8664
Engine Rebuild & Restorations
Old 07-09-2008, 05:27 PM
Here's mine.
--clutch-monkey
jh225's Avatar
Great, thanks.
Now there is another question though.
In the post below yours, the strut end is mounted on the other side of the plate. Which is correct?
I would imagine that the bolt has a smooth (unthreaded) portion where it contacts the eyelet of the strut, no? (so it can pivot smoothly)
Old 07-09-2008, 05:35 PM
Mine is on the wrong side because the hinge is bent. The one you quoted is correct. The head of the bolt should be inboard.
--clutch-monkey
Old 07-09-2008, 05:37 PM
jh225's Avatar
Once again, Pelican guys come through quick as lightning.
Thanks.
Old 07-09-2008, 05:52 PM
9dreizig's Avatar
Send a message via AIM to 9dreizig
Thanks.
Actually we're Turbo Pelicans, that's where the real braintrust hang out!! ( now go get a turbo and come back to visit LOL)
"Todd"
98 Tahoe ,2007 Saturn Vue
86 930 black and stock, 80 930 blue tracdog
91 Spec Miata (yeah I race a chick car)
"life"ll kill ya" Warren Zevon
Old 07-10-2008, 07:40 AM
That's why we're quick as lightning!
--clutch-monkey
Old 07-10-2008, 07:42 AM
jh225's Avatar
Scuffed and sanded it up, primed, painted last night. Got it mounted up today. Works perfectly.
Old 07-10-2008, 02:03 PM
A fellow Pelacanite
NathanUK's Avatar
So your Carrera is not a sport? Yet it still has the bracket on the firewall to mount the strut?
1981 UK 930. G50/01 shortened, 964 3.8RS Fibreglass Body Kit, 18" Alloys 8.5" F & 10" R, 225's F & 285's R, Special Colour Metallic Blue Paint, FIA Sparco Evo's, A/C and Air Pump removed, Electronic Boost Controller, GHL Headers, Tial46 WG.
Fitting - New service kit.
Needs Fitting - Innovate XD-16 Kit, Kokeln IC. Stephen's K27 HFS, EVO Intake Assy & his Modded USA Fuel Head.
1983 UK 911 3.2 Carrera Sport Coupe. Black, Black Leather with Red Piping, Black Alloy Gear Knob, K&N Air Filter Element, Turbo Tie rods.
Needs Fitting - K&N CO Sensor, Round A/F Dial Gauge, Factory Short Shift Kit.
http://www.danasoft.com/sig/Iamnotanumber.jpg
Old 07-11-2008, 12:02 PM
jh225's Avatar
Sport?
Package would include what?
This car has ZERO options When you look at the underhood tag, it lists the only option as CO2 (cat)
Old 07-11-2008, 04:11 PM
Cynical Misanthrope
AFM744's Avatar
Send a message via Yahoo to AFM744
My '89 Carrera 3.2 had the bracket on the firewall. I had to fab the right side hinge bracket when I added a Carrera tail, but the firewall bracket was there.
X-1, AFM744, Jon, '92 C2 Turbo
JE 8:1 pistons, 964 cams, 38mm intakes ported/polished/twinplugged, ARP hardware, B&B headers/exhaust, 355whp. Full-blown GT35R 3.2 intake EFI pending...
Where my misspent time and money is currently going.
Old 07-11-2008, 04:28 PM
All the deck and hood shocks use a pin with a groove and that fiddly little clip that ends up jumping somewhere in the engine bay at least once, surely?
'77 S with '78 930 power and a few other things.
Old 07-11-2008, 05:47 PM
Mine has a threaded nut attached to the outboard side. The driver side has the pin and clip.
--clutch-monkey
Old 07-11-2008, 05:50 PM
jh225's Avatar
Actually, no they don't.
The driver side hinge uses a bolt on the hinge side mount. There is a threaded nut to accept it.
Since I originally posted this thread, I found out even more info.
I was informed by a very experienced and certified Porsche tech and well known rally car builder that the plate was/is used on the right side hinge due to the fact that if they used a mount like the left side, it would strike the 930 airbox. And in looking at the setup, it makes perfect sense.
Old 07-11-2008, 09:14 PM
A fellow Pelacanite
NathanUK's Avatar
My 3.2 carrera has pins and clips, that car is very very original. As for my 930 there is no point me even looking
Old 07-12-2008, 04:50 AM
