juicersr's Avatar
Half-finned Turbo cylinders - What was the reasoning?
Can someone explain what the factory's thinking was on the half-finned stock Turbo cylinders? With the massive increase in heat from the Turbo'd engine, it seems counterintuitive (at least to me) to do something which would limit heat dispersal. Which years did they put them on? Has time proven, like the thermal reactors, for them to be flawed, with everyone ditching them in favor of later fully-finned/ aftermarket cylinders? Thanks
DZ12,935K3,934,2.8RSR
Ducati 900ss/GhezziBrian STW
dzugautomobili.com
Old 07-27-2008, 12:38 PM
A fellow Pelacanite
NathanUK's Avatar
You are spot on. They had a theory, but it didn't really work.
They thought that if they only finned one side then there wouldn't be less expansion compared to the other side as air can only blow on the top and then the sides, never the bottom.
Air blew on to the flat surface (top).
The 964t has fully finned. RUF also had theirs made fully finned.
1981 UK 930. G50/01 shortened, 964 3.8RS Fibreglass Body Kit, 18" Alloys 8.5" F & 10" R, 225's F & 285's R, Special Colour Metallic Blue Paint, FIA Sparco Evo's, A/C and Air Pump removed, Electronic Boost Controller, GHL Headers, Tial46 WG.
Fitting - New service kit.
Needs Fitting - Innovate XD-16 Kit, Kokeln IC. Stephen's K27 HFS, EVO Intake Assy & his Modded USA Fuel Head.
1983 UK 911 3.2 Carrera Sport Coupe. Black, Black Leather with Red Piping, Black Alloy Gear Knob, K&N Air Filter Element, Turbo Tie rods.
Needs Fitting - K&N CO Sensor, Round A/F Dial Gauge, Factory Short Shift Kit.
http://www.danasoft.com/sig/Iamnotanumber.jpg
Old 07-27-2008, 01:35 PM
juicersr's Avatar
So are the 'half-fins' pretty much junk? Anyone here use them in a rebuild? Am putting together a 'budget' turbo engine based on a 3.0 engine and was toying with the idea of using them.
dzugautomobili.com
Old 07-27-2008, 02:50 PM
sudo apt-get purge 930
equality72521's Avatar
I don't know that I'd call them junk seeing as every 930 through 1989 used them and have been pretty darned reliable engines.
--clutch-monkey
Old 07-27-2008, 02:52 PM
juicersr's Avatar
Through '89 huh? That's what i wanted to know. Thought they were just for the early years (3.0) or something. Thanks Mark.
dzugautomobili.com
Old 07-27-2008, 02:56 PM
A fellow Pelacanite
NathanUK's Avatar
As I stated the 964t and RUF were the first cars to have fully finned.
I don't intend to change mine unless they break...
Old 07-28-2008, 12:29 PM
Smart quod bastardus
fredmeister's Avatar
Porsche tried to control thermal expansion evenly by biasing the fins as stated above.
Whether this had an effect or not appears no as they later made them fully finned.
I would not sya there junk unless they are worn.
1979 930 Turbo....3.4L, 7.5to1 comp, SC cams, full bay intercooler, Rarlyl8 headers, Garret GTX turbo, 36mm ported intakes, Innovate Auxbox/LM-1, custom Manually Adjustable wastegate housing (0.8-1.1bar),--running 0.95 bar max
---"When you're racing it's life! Anything else either before or after, is just waiting"
Old 07-28-2008, 02:30 PM
A fellow Pelacanite
NathanUK's Avatar
The FF might offer a little less chance of detonation but unlike twin plugging costs a fortune if you go with RUF 3.4 Mahles.
Old 07-28-2008, 02:44 PM
