Injector Blocks
Having some Euro SC heads redone. I would like to have the intake matched to the heads, but do not want to run & port the plastic blocks. I read the post on the inlet spacers & a couple of sources for aluminium injector blocks. Any other suggestions & or sources?
88' 930
03 Tacoma, 04 Duramax, 06 R350 Benz
If you are traveling at the speed of light & turn on your headlights, does anything happen?
Old 08-01-2008, 08:01 PM
I am going through the same problem. After some careful consideration, I decided not to use the after market aluminum blocks. I believe Porsche used the phenolic intake blocks to keep heat from being absorbed by the injectors. I predict hot start problems from leaking injectors due to the heat.
My intake and heads were ported by someone else and my injector blocks were bored out.
Some people say that Porsche used the 32mm spacer to increase velocity at low end and help with off boost torque.
I've also heard that a few 930s's came with 38mm blocks. It makes me wonder why Porsche used those if there was the issue of off boost torque. Maybe they saved the good stuff for the "s" model? I'm only speculating here and using deductive reasoning for my own choices.
Personally I think the off boost torque can be helped by using a better ignition curve and camshafts. I haven't gotten that far yet so I can't speak from my own experience.
Anyway, I ended up boring new injector blocks to 36mm to better match what was already done to the engine.
If the crack they crack. However, the old ones that were previously bored cracked and the very bottom where the material is thicker. So, go figure.
Old 08-01-2008, 09:05 PM
After the next project
x98boardwell's Avatar
Option
Neil Harvey at Performance Developments in CA. He at one point was making these style injector blocks and has the molds to make them again if needed.
Hope this helps,
Bryan
Old 08-01-2008, 09:20 PM
I had a problem sourcing these. I found them here http://www.turbokraft.com/.
They can make custom sizes and come with phenolic blocks for insulation. Good luck with your project.
Old 08-04-2008, 10:33 AM
Me like track days
Craig 930 RS's Avatar
Great information!
http://www.turbokraft.com/catalog/product_info.php?cPath=1_5&products_id=102
Perfect, I just may do this in the near future.
- Craig 3.4L, SC heads, 964 cams, B&B headers, K27 HF ZC turbo, Ruf IC. WUR & RPM switch, IA fuel head, Zork, G50/50 5 speed. 438 RWHP / 413 RWTQ -
"930 is the wild slut you sleep with who tries to kill you every time you "get it on" - Quote by Gabe
Movie: 930 on the dyno
Old 08-04-2008, 10:21 PM
Used the suggestion from Turbodog & went with the Turbocraft injector blocks. Talked to Chris over there, exactly what I needed. Has Phenolic spacers with the Aluminum Block on top that holds the injector. Made size specific as to my application. Cost some $$ but what is new? Will post pictures after they come in.
88' 930
Old 08-07-2008, 11:14 AM
Here are pictures. Thing of beauty. Also, ordered on the 5th, received on the 8th & I am in Hawaii. Talk about fast. These are the Turbokraft Blocks in 38mm.
88' 930
Old 08-08-2008, 07:26 PM
A fellow Pelacanite
NathanUK's Avatar
They look great!
1981 UK 930. G50/01 shortened, 964 3.8RS Fibreglass Body Kit, 18" Alloys 8.5" F & 10" R, 225's F & 285's R, Special Colour Metallic Blue Paint, FIA Sparco Evo's, A/C and Air Pump removed, Electronic Boost Controller, GHL Headers, Tial46 WG.
Fitting - New service kit.
Needs Fitting - Innovate XD-16 Kit, Kokeln IC. Stephen's K27 HFS, EVO Intake Assy & his Modded USA Fuel Head.
1983 UK 911 3.2 Carrera Sport Coupe. Black, Black Leather with Red Piping, Black Alloy Gear Knob, K&N Air Filter Element, Turbo Tie rods.
Needs Fitting - K&N CO Sensor, Round A/F Dial Gauge, Factory Short Shift Kit.
http://www.danasoft.com/sig/Iamnotanumber.jpg
Old 08-09-2008, 01:27 AM
TurboKraft's Avatar
Thanks for the kind words, Akila!
Chris Carroll
TurboKraft, Inc.
Tel. 480.969.0911
email: info@turbokraft.com
http://www.facebook.com/TurboKraft - http://www.instagram.com/TurboKraft
Old 08-13-2008, 12:22 PM
Those look very well made! If mine crack (fingers crossed) I will probably end up getting a set of those as well.
Old 08-13-2008, 03:37 PM
iamchappy's Avatar
There website has been dead for over a week, what did those injector blocks run you..$
914 6 Turbo twinplug 3.12
87 924S
Lexus SC400
Lexus LS400
Old 08-13-2008, 09:14 PM
With shipping 5ish.
88' 930
Old 08-13-2008, 09:28 PM
iamchappy's Avatar
Less than a hun a piece and never crack, sounds sort of reasonable to me, half of that would be a slam dunk deal .. .. thanks!
87 924S
Lexus SC400
Lexus LS400
Old 08-13-2008, 09:57 PM
