Oil Leak
On my 3.3 turbo it has developed a significant oil leak on the right hand side (same side as Oil tank) it drops mainly on the right side of the exhaust at the forward end
Any ideas?
Old 07-22-2008, 01:11 AM
resident samsquamch
sand_man's Avatar
Many leaks start on top and make their way down. It is sometimes helpful to clean/de-grease the engine and watch carefully as the engine idles - often times the leaks are more obvious on a clean(er) canvas...especially if it's "significant" as you have indicated.
Some possibilities:
-the low oil pressure warning light sensor, located on top of the engine in between cylinders three and six.
-Valve covers.
-Rocker shafts.
-Oil return tubes.
-Engine mounted oil cooler seals, and/or the "S" hose that connects the cooler to the oil tank.
-jeff
Old 07-22-2008, 05:26 AM
Macht Schnell
les_garten's Avatar
You may want to consider this?
http://www.popularmechanics.com/how_to_central/automotive/1272471.html?page=1
http://autorepair.about.com/od/otherodddiyjobs/a/findleaks_2.htm
---Les Garten---85 930, Andial IC, GHL Headers, Fabspeed Dual, K-27 HF2, 3.4 JE Full Finned 7.5:1 CR, 964 CAM'd, Carerra 3.2 Manifold Cut/Flipped, Tec3r, Siemans 55#, GSF Fuel Rails, Clewett Crank Trigger, Clewett Cam Trigger,Dual Plugged, ARP Head Studs/Rod Bolts, Clewett Wires.Tial 46mm WG, Tial 50mm BOV, WEVO Shifter,934 Boost Gauge, Wideband EGO Sensor/Gauge, C2T Head Gaskets, '88 MB 300TE,BMW R100RT
Old 07-22-2008, 08:49 AM
