-   911 / 930 Turbo & Super Charging Forum (http://forums.pelicanparts.com/forumdisplay.php?f=222)
-   -   headers leaking (http://forums.pelicanparts.com/showthread.php?t=422299)
JHP 07-28-2008 02:18 PM
headers leaking
Hi
I have a pair of b&b headers with the heat boxes that are leaking.
However, i can not see an visual leaks. So my question is can they be leaking inside the heater box? I am thinking about cutting out the heater box to see but before i do i wanted to check if it is even possible to leak in there.. any welds in there that may crack or is it all one pipe?
also, is there a special method to use to check for leaks?.. I am thinking of just feeling up the header with water?
thanks in advance
NathanUK 07-28-2008 02:42 PM
Sometimes they can leak where the heater box got welded to the pipes/tubing.
